Short, compact, economical mini USB cable, perfect for charging and syncing Blackberry, mobile phones and cameras.
The USB2HABM1 high quality USB A to Mini B Cable provides one (4-pin) USB Type A male connector and one Mini B (5-pin) male connector, and can support data high speed USB 2.0 transfer rates of up to 480Mbps.
A high quality replacement for connecting your digital camera (Canon, Sony, Hewlett-Packard) to a host computer, this Mini USB 2.0 cable also delivers a cost-effective way to maximize the file transfer performance of your MP3 player, PDA, or digital camcorder.
Expertly designed and constructed of only top quality materials, the A to Mini B USB 2.0 cable provides pure digital data transfers for sharper, more natural images and sound at higher speeds.
- StarTech.com 1 ft Mini USB 2.0 Cable - A to Mini B - M/M - USB cable - 30 cm
- USB cable
- Length
- 30 cm
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- Mini-USB Type B - male
- USB / USB 2.0
- Grey
- Limited lifetime warranty
- Designed For
- P/N: SAT1810U2, SLMSOPTB, PEXUSB7LP, UNI2510U2V, SAT2510U2F
- USB cable
- Length
- 30 cm
- Grey
- Connector
- USB / USB 2.0, FCC
- Designed For
- StarTech.com 1.8in USB to Micro SATA Hard Drive Enclosure, 2.5in Tool-less USB 2.0 to IDE SATA External Hard Drive Enclosure, 2.5in USB FireWire SATA External Hard Drive Enclosure, 7 Port PCI Express Low Profile High Speed USB 2.0 Adapter Card, USB to Slimline SATA CD/DVD Optical Drive Enclosure
StarTech.com 6 ft Mini USB Cable - A to Mini B | In Stock | £3.17 |
StarTech.com 3 ft Mini USB 2.0 Cable - A to Mini B | In Stock | £3.18 |
StarTech.com 10 ft USB 2.0 Cable - USB A to Mini B | In Stock | £3.31 |
StarTech.com Mini USB to Micro USB Adapter | In Stock | £4.96 |
StarTech.com 1 ft Mini USB 2.0 Cable - A to Mini B - M/M | In Stock | £3.16 |
StarTech.com 6in Mini USB 2.0 Cable - A to Mini B | In Stock | £3.07 |
StarTech.com 3 ft Mini USB Cable - A to Left Angle Mini B | In Stock | £3.35 |
StarTech.com 3ft Right Angle Mini USB Cable | In Stock | £3.35 |
StarTech.com 6 ft Mini USB Cable - A to Right Angle Mini B | In Stock | £3.50 |
