Short, compact, economical mini USB cable, perfect for charging and syncing Blackberry, mobile phones and cameras.
The USB2HABM1 high quality USB A to Mini B Cable provides one (4-pin) USB Type A male connector and one Mini B (5-pin) male connector, and can support data high speed USB 2.0 transfer rates of up to 480Mbps.
A high quality replacement for connecting your digital camera (Canon, Sony, Hewlett-Packard) to a host computer, this Mini USB 2.0 cable also delivers a cost-effective way to maximize the file transfer performance of your MP3 player, PDA, or digital camcorder.
Expertly designed and constructed of only top quality materials, the A to Mini B USB 2.0 cable provides pure digital data transfers for sharper, more natural images and sound at higher speeds.
- StarTech.com 1 ft. (0.3 m) USB to Mini USB Cable - USB 2.0 A to Mini B - Gray - Mini USB Cable (USB2HABM1) - USB cable - USB to mini-USB Type B - 30 cm
- USB cable
- Length
- 30 cm
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- Mini-USB Type B - male
- USB / USB 2.0
- Grey
- Limited lifetime warranty
- Designed For
- P/N: NOTECONS01, NOTECONS02, NOTECONS02X, SATDOCK25U, SV231USBLC, SV565HDIP, USBEXTAA10BK, USBEXTAA3BK, USBEXTAA6BK, USBPLATE4
- USB cable
- Length
- 30 cm
- Grey
- Connector
- USB / USB 2.0, FCC
- Designed For
StarTech.com Mountable 4 Port Rugged Industrial USB Hub | In Stock | £63.70 |
StarTech.com 1 ft Panel Mount USB Cable B to B - F/M | In Stock | £6.59 |
StarTech.com Mini USB to Micro USB Adapter | In Stock | £4.82 |
StarTech.com Mountable Rugged Industrial 7 Port USB Hub | In Stock | £83.34 |
StarTech.com 6in Mini USB 2.0 Cable - A to Mini B | In Stock | £4.05 |
StarTech.com 3 ft Panel Mount USB Cable B to B - F/M | In Stock | £5.69 |
