Extend your eSATA Interface and Screw-mount it into a Panel. This 1-foot panel mount eSATA cable features an eSATA male connector on one end, and an eSATA panel mount (female) molded connector on the other, providing a well-secured, easy-to-access eSATA connection on any machine port or faceplate.
- StarTech.com 1 ft eSATA Panel Mount Cable - F/M - SATA to eSATA cable - 30 cm
- Interface Speed
- Serial ATA 150/300/600
- Length
- 30 cm
- Connector
- 7 pin Serial ATA - female
- Connector (Second End)
- 7 pin external Serial ATA - male
- Red
- Limited lifetime warranty
- Storage Cable Type
- Interface Speed
- American Wire Gauge (AWG)
- 26
- Length
- 30 cm
- Red
- Connector
- RoHS
StarTech.com 6 ft Shielded External eSATA Cable M/M | In Stock | £10.50 |
StarTech.com 1 ft Panel Mount USB Cable A to A - F/M | In Stock | £4.93 |
StarTech.com 1 ft Panel Mount USB Cable - USB A to Motherboard Header Cable F/F | In Stock | £5.49 |
StarTech.com 1 ft Panel Mount USB Cable B to B - F/M | In Stock | £6.60 |
StarTech.com 3 ft Standard HDMI Cable for Panel Mount - F/M | In Stock | £9.49 |
StarTech.com 3 ft 20 pin DisplayPort Extension Panel Mount Cable - M/F | In Stock | £17.88 |
