Connect your VGA monitor with the highest quality connection available. The MXT101MMHQ1 High Resolution VGA Cable (1 ft) is designed to provide the highest video quality possible through VGA, ideally suited for high resolution applications of 1920x1200 and above.
This durably constructed coaxial VGA video cable (HD15 to HD15) eliminates the picture "ghosting" and fuzzy images that are inherent to non-coaxial VGA cables, while delivering superior EMI interference protection by using ferrite cores near the connector ends.
- StarTech.com 1 ft Coax High Resolution Monitor VGA Cable HD15 M/M - VGA cable - 31 cm
- VGA cable
- Technology
- Triple shielded twisted pair coaxial
- Molded, ferrite bead
- Length
- 31 cm
- Connector
- HD-15 (VGA) - male
- Connector (Second End)
- RoHS
- Black
- Limited lifetime warranty
- Designed For
- P/N: DP2VGAA, DVI2VGAE
- VGA cable
- Technology
- Shielding Material
- Aluminum mylar foil with braid
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Nickel
- Length
- 31 cm
- Black
- Connector
- 15 pin HD D-Sub (HD-15) - male
- RoHS
- Designed For
StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M | In Stock | £5.74 |
StarTech.com Right Angle VGA to VGA Cable Adapter Type 1 - M/F | In Stock | £6.09 |
StarTech.com 20 ft Coax High Resolution Monitor VGA Cable HD15 M/M | In Stock | £9.79 |
StarTech.com 1 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M | In Stock | £4.72 |
