StarTech.com 1 ft Coax HD15 VGA to 5 BNC RGBHV Monitor Cable - M/F
Quicklinx: 6LC7WS00 Mfr#: VGABNCMF1
Type: VGA
Length: 30cm
£6.58 ex VAT
£7.89 inc VAT
Connect a BNC video source to a VGA distribution amplifier or PC. The VGABNCMF1 1-foot Coax HD15 VGA to 5 BNC RGBHV Adapter Cable features an HD15 VGA (male) connector and 5 BNC (RGBHV) (female) connectors, allowing you to connect your existing BNC video source to a VGA distribution amplifier or PC.
The cable can also be used with a VGA out signal, breaking out to 5 BNC female connectors that can be used with a 5 BNC (M-M) cable for use with a BNC monitor/display.
StarTech.com 1 ft. (0.3 m) VGA to BNC Cable - HD15 VGA to 5 BNC - Male/Female - BNC Cable (VGABNCMF1) - VGA cable - 30 cm
VGA cable
Coaxial
Length
30 cm
Connector
5 x BNC - female
Connector (Second End)
HD-15 (VGA) - male
RoHS
VGA cable
Coaxial
American Wire Gauge (AWG)
28
Length
30 cm
Connector
5 x BNC - female
RoHS
6LC7 StarTech.com 6 ft Coax HD15 VGA to 5 BNC Monitor Cable – M/M In Stock £9.77
6LC7 StarTech.com 10 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F In Stock £10.15
6LC7 StarTech.com 6 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F In Stock £5.82
6LC7 StarTech.com 3 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F In Stock £6.38
6LC7 StarTech.com 3 ft HD15 to Component RCA Breakout Cable Adapter - M/M In Stock £10.15
Type: VGA
Length: 30cm
Price Range Ex VAT: 0 - 50
