Make Ethernet connections with PoE support. This high quality cable ensures dependable Ethernet connectivity, supporting high level of performance is an excellent choice for Power over Ethernet (PoE) applications. All of the Cat 6a cables are constructed of high quality shielded copper pairs to protect against noise and EMI/RFI interference, ensuring that the Cat6a cables are more than suitable for Ethernet networks and Power over Ethernet applications.
- StarTech.com 1 ft Blue Cat6a / Cat 6a Shielded Patch Cable 1ft - patch cable - 30 cm - blue
- Patch cable - CAT 6a
- Technology
- Shielded twisted pair (STP)
- Wiring Scheme
- T568B
- Shielding Material
- Aluminium-polyester foil
- Wires per Cable
- 8 wires
- Molded
- Length
- 30 cm
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Blue
- Limited lifetime warranty
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 26
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Molded
- Length
- 30 cm
- Blue
- Connector
- RJ-45 - male
- RJ-45 - male
- UL 444, RoHS - up to 500 MHz
