StarTech.com 1.5m HDMI to DVI-D Cable - M/M
Quicklinx: 93WPWS00 Mfr#: HDDVIMM150CM
Length: 1.5m
More than 50 in stock
£8.45 ex VAT
£10.14 inc VAT
The HDDVIMM150CM HDMI to DVI-D cable comes in a non-standard 1.5 meter/5 foot cable length allowing for a convenient connection distance and enabling you to position your DVI-D or HDMI-enabled devices as needed.
This bi-directional cable enables you to connect a DVI-D video card to a display that incorporates HDMI technology, or enables you to connect an HDMI-enabled output to a DVI-D capable display.
A valuable addition to any digital signage, multimedia or home theater application, this high-performance cable is designed to provide the best quality picture available through HDMI technology or DVI digital connections.
StarTech.com 1.5m HDMI to DVID Cable M/M - video cable - HDMI / DVI - 1.5 m
Cable
Video cable - HDMI / DVI
Shielded
American Wire Gauge (AWG)
28
Length
1.5 m
Connector
DVI-D - male
Connector (Second End)
HDMI - male
Moulded, strain relief
Cable Type
Video cable
Interface Supported
HDMI / DVI
Shielded
28
Jacket Material
PVC
Shielding Material
Length
1.5 m
Plated Connector
Gold
Connector
18+1 pin digital DVI (Single-Link) - male
19 pin HDMI Type A - male
RoHS
Limited warranty - lifetime
93WP StarTech.com 10m HDMI to DVI-D Cable - M/M In Stock £45.03
93WP StarTech.com 2m High Speed HDMI® Cable to DVI Digital Video Monitor In Stock £7.82
93WP StarTech.com 3m HDMI to DVI-D Cable - M/M In Stock £9.09
93WP StarTech.com 5m HDMI to DVI-D Cable – M/M In Stock £14.11
93WP StarTech.com 15m HDMI to DIV-D Cable – M/M In Stock £77.88
93WP StarTech.com 1m HDMI to DVI-D Cable - M/M In Stock £7.20
93WP StarTech.com 1.5m HDMI to DVI-D Cable - M/M In Stock £8.45
93WP StarTech.com 7m HDMI to DVI-D Cable - M/M In Stock £29.09
Length: 1.5m
Price Range Ex VAT: 0 - 50
