StarTech.com 1:5 SATA III Port Multiplier
Quicklinx: B14CWS00 Mfr#: ST521PMINT
Connect five SATA drives to a single internal SATA 6Gbps host connection. The ST521PMINT 1-to-5 SATA drive port multiplier lets you connect five individual SATA hard drives to a single SATA host controller, vastly increasing the storage capacity of your computer system.
The ST521PMINT optimizes port usage enabling you to connect up to five SATA drives to a single SATA port. To ensure maximum performance the SATA port multiplier supports SATA III host controllers and hard drives, with transfer speeds up to 6 Gbps, so you can experience fast performance, even with 5 individual drives connected.
For a hassle-free installation, you can mount the adapter into any new or legacy desktop expansion slot, including: PCI, AGP, and PCIe. To ensure compatibility with most computer cases, full-profile and low-profile mounting brackets are included. The HDD adapter also includes HDD activity LED headers, so you can connect your computer case LEDs to the card for full activity reporting.
StarTech.com Port multiplier controller - 5-port SATA to single SATA III - storage controller - SATA 6Gb/s - SATA 6Gb/s
Storage controller - internal - low profile
Bus Type
SATA 6Gb/s
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive, solid state drive
Max Storage Devices Qty
5
12 cm x 9.3 cm x 1.8 cm
43 g
Host Bus
SATA 6Gb/s
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
5
JMicron JMB575A
5 x SATA 6Gb/s - eSATA (internal)
Low-profile bracket, full-height bracket
1 x Serial ATA cable - external , 1 x power splitter - external
Support port multiplier, tested with up to 6TB 7200 RPM hard drives
FCC, RoHS
12 cm
9.3 cm
1.8 cm
43 g
5 °C
50 °C
20 - 80%
B14C StarTech.com 3.5in Universal Hard Drive Mounting Bracket Adapter for 5.25in Bay In Stock £2.96
B14C StarTech.com 18in Latching SATA Cable In Stock £5.24
B14C StarTech.com 24in Latching SATA Cable In Stock £5.98
B14C StarTech.com 3.5in Hard Drive to 5.25in Front Bay Bracket Adapter In Stock £5.39
B14C StarTech.com 2.5in SATA Hard Drive to 3.5in Drive Bay Mounting Kit In Stock £4.38
B14C StarTech.com Bi-Directional SATA IDE Adapter Converter In Stock £11.77
B14C StarTech.com 12in Latching SATA to Right Angle SATA Serial ATA Cable In Stock £4.86
B14C StarTech.com 6in Latching SATA Cable In Stock £4.98
B14C StarTech.com 2 Port PCI Express SATA 6 Gbps eSATA Controller Card - 2 Int/2 Ext In Stock £30.82
B14C StarTech.com Dual 2.5" to 3.5" HDD Bracket for SATA Hard Drives - 2 Drive 2.5" to 3.5" Bracket In Stock £7.83
B14C StarTech.com Dual mSATA SSD to 2.5" SATA RAID Adapter Converter In Stock £43.44
