Sync your Micro USB, iPhone, iPod or iPad devices using a single cable. The USB2UBADC1M Apple (30-pin) Dock Connector/Micro USB to USB Combo Cable (0.65m) offers a simple and reliable solution for connecting Micro USB or iOS-enabled mobile digital devices to your computer, for syncing or charging.
For charging your devices and syncing data between your computer and your iPhone /iPad /iPod or Micro USB devices, the cable features a combination Micro USB connector and Dock Connector on one end, and a standard USB male connector on the other, enabling you to connect directly (or through a dock) to a computer USB port. Or, to simply charge the device, connect it to a USB wall outlet power adapter.
This durable cable is Apple MFi certified.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other mobile device, you can use this 0.65m 30-pin Dock/Micro USB to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
- StarTech.com Apple 30-pin Dock Connector or Micro USB to USB Combo Cable - charging / data cable - 65 cm
- Cable
- Charging / data cable
- American Wire Gauge (AWG)
- 28
- Length
- 65 cm
- Black
- Connectors
- USB - male
- Connectors (Second End)
- Apple Dock - male , Micro-USB Type B - male
- Sync and charge
- Limited lifetime warranty
- Cable Type
- 28
- Jacket Material
- PVC
- Length
- 65 cm
- Recommended Use
- Mobile phone
- Sync and charge
- Black
- Connectors
- 4 pin USB Type A - male
- Apple Dock connector - male , 5 pin Micro-USB Type B - male
- RoHS, MFI
- Limited warranty - lifetime
