StarTech.com 0.65m 2.1ft 10G SFP+ DAC Cable
Quicklinx: D9TBWS00 Mfr#: JD095CST
Length: 65cm
Colour: Black
Select:
£27.19 ex VAT
£32.62 inc VAT
Connect your HP 10GbE SFP+ network devices with this cost-effective, passive Twinax copper cable. This 10G SFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This passive twinaxial cable is a fully hot-pluggable, direct-attach cable, supporting 10 Gigabit Ethernet applications connected through SFP+ (Small Form-Factor Pluggable) ports.
Designed for short-length, high-speed interconnects, this low-power, low-latency Twinax cable is a cost-effective alternative to fiber-optic cable assemblies, supporting short-distance applications such as point-to-point in-rack network switch or server connections.
StarTech.com HP JD095C Compatible SFP+ DAC Twinax Cable - 0.65 m (2.1 ft.) - 10GBase direct attach cable - 65 cm - black
10GBase direct attach cable - SFF-8431/SFF-8432
Twinaxial
Passive cable
Length
65 cm
Connector
SFP+ - latched
Connector (Second End)
SFP+ - latched
HP JD095C
Network Cable Type
Twinaxial
Jacket Material
PVC
American Wire Gauge (AWG)
30
Impedance
100 Ohm
Passive cable
Length
65 cm
40 g
Connector
SFP+ - latched
SFP+ - latched
HP JD095C
FCC, RoHS, MSA
70 °C
Length: 65cm
Colour: Black
Price Range Ex VAT: 0 - 50
