StarTech.com 0.65m (2 ft) Samsung Galaxy Tab Dock Connector or Micro USB to USB Combo Cable
Quicklinx: 92Q1WS00 Mfr#: USB2UBSDC
Select:
Charge or Sync your Micro USB device or Samsung Galaxy Tab using a single cable. The USB2UBSDC 0.65m/2 ft Samsung Galaxy Tab Dock Connector/Micro USB to USB Combo Cable offers a simple and reliable solution for connecting your Micro USB device or your Samsung Galaxy Tab to your computer, for charging or syncing.
This convenient cable features a Samsung Galaxy Tab dock connector as well as a Micro USB connector on one end, and a USB connector on the other, providing the option to charge or dock either a Samsung Galaxy Tab or a Micro-USB-equipped device, using a single, handy cable.
The USB2UBSDC is designed and constructed for maximum durability, making it a dependable replacement for damaged or misplaced sync cables.
StarTech.com 65cm Samsung Galaxy Tab Dock Connector Micro USB to USB Cable - charging / data cable kit - 65 cm
Cable
Charging / data cable kit
Double shielded
American Wire Gauge (AWG)
28
Length
65 cm
Sync and charge
P/N: ST7C51224, ST7C51224EU, ST7CU35122
Cable Type
Double shielded
28
Jacket Material
PVC
Shielding Material
Length
65 cm
Plated Connector
Nickel
Recommended Use
Tablet
Sync and charge
Details
Included Qty x Type
USB cable - 4 PIN USB Type A (male) to 5 pin Micro-USB Type B (male) , Tablet charging / data adapter - Samsung 30-pin Dock Connector (male) to 5 pin Micro-USB Type B (female)
RoHS
Limited warranty - lifetime
