StarTech.com 0.5m White Thunderbolt Cable - M/M
Quicklinx: 8SFYWS00 Mfr#: TBOLTMM50CMW
Length: 50cm
21 in stock
£27.01 ex VAT
£32.41 inc VAT
The Thunderbolt cables deliver the dependability you need to harness the speed and power of Thunderbolt technology and combine both data and video into a single high-performance cable.
You can find the perfect connection to suit any application, with the wide range of Thunderbolt cables. Compatible with Thunderbolt 1 (10 Gbps) and Thunderbolt 2 (20 Gbps) devices, the cables support bi-directional data transfer capability and power delivery for bus-powered devices. All of the Thunderbolt cables are constructed of highly durable materials and designed to the highest quality standards. Plus, the optical cables use optical fiber instead of copper so you don't need to worry about signal loss or EMI interference.
StarTech.com Thunderbolt Cable - M/M - Thunderbolt cable - 50 cm
Thunderbolt cable
Double shielded
Length
50 cm
Connector
Mini DisplayPort - male
Connector (Second End)
Thunderbolt 2
White
Apple iMac; Mac mini; MacBook Air; MacBook Pro
Thunderbolt cable
Double shielded
Jacket Material
PVC
American Wire Gauge (AWG)
34
Plated Connector
Nickel
Length
50 cm
White
34 g
Connector
Thunderbolt 2, FCC, RoHS
Apple iMac , Apple Mac mini , Apple MacBook Air , Apple MacBook Pro
8SFY StarTech.com 3m White Thunderbolt Cable - M/M In Stock £52.70
8SFY StarTech.com 1m White Thunderbolt Cable - M/M In Stock £31.57
8SFY StarTech.com 0.5m White Thunderbolt Cable - M/M In Stock £27.01
Length: 50cm
Price Range Ex VAT: 0 - 50
