StarTech.com 0.5m White Cat6 Patch Cable
Quicklinx: CNDCWS00 Mfr#: N6PATC50CMWH
Length: 50cm
Colour: White
More than 50 In Stock
£3.51 ex VAT
£4.21 inc VAT
StarTech.com N6PATC50CMWH. Cable length: 0.5 m, Cable standard: Cat6, Connector 1: RJ-45. Weight: 26 g. Package width: 200 mm, Package depth: 220 mm, Package height: 10 mm
  • Reliable performance
    This cable features gold-plated connectors that enhance conductivity and reduce the risk of corrosion, ensuring a stable connection for data transmission.
  • Enhanced durability
    The PVC jacket protects the internal wiring from physical damage while maintaining flexibility and ease of routing in tight spaces.
  • Efficient wiring scheme
    The T568B wiring scheme provides consistent performance and maintains network reliability across different environments.
  • Flexible installation options
    This 50 cm cable length offers flexibility for various networking setups, whether at home or in an office, catering to a range of distances and configurations.
StarTech.com 50cm CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, White, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC50CMWH) - network cable - 50 cm - white
Network cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded, snagless, stranded, strain relief, PoE ready
Length
50 cm
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
White
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
50 cm
26 g
White
Connector
RJ-45 - male
RJ-45 - male
RoHS, ETL, TIA/EIA-568-B - up to 500 MHz
CNDC StarTech.com 0.5m Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £3.51
CNDC StarTech.com 0.5m Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £3.59
CNDC StarTech.com 0.5m Gray Cat6 Patch Cable In Stock £3.51
CNDC StarTech.com 0.5m Green Cat6 Patch Cable In Stock £3.51
CNDC StarTech.com 0.5m Orange Cat6 Patch Cable In Stock £3.51
CNDC StarTech.com 0.5m Purple Cat6 Patch Cable In Stock £3.51
CNDC StarTech.com 0.5m Red Cat6 Patch Cable In Stock £3.51
CNDC StarTech.com 0.5m White Cat6 Patch Cable In Stock £3.51
CNDC StarTech.com 0.5m Yellow Cat6 Patch Cable In Stock £3.51
Length: 50cm
Colour: White
