StarTech.com 0.5m USB 2.0 C to B Cable
Quicklinx: CZJSWS00 Mfr#: USB2CB50CM
Length: 50cm
33 in stock
£9.33 ex VAT
£11.19 inc VAT
Connect USB 2.0 USB-B devices to your USB-C or Thunderbolt 3 computer. This USB-C to USB-B printer cable lets you connect your USB 2.0 peripheral devices, such as a portable printer or scanner, or an external drive to your USB Type-C laptop or tablet. The cable is also compatible with Thunderbolt 3 ports.
The non-standard 0.5-meter cable is great for close-range connections. It lets you set up in small offsite workspaces, or in a coffee shop or hotel room, so that you can install your equipment without excess cable getting in your way.
StarTech.com USB-C to USB-B Printer Cable - M/M - 0.5 m - USB 2.0 - USB-C cable - 50 cm
USB-C cable
Length
50 cm
Connector
24 pin USB-C - male
Connector (Second End)
4 pin USB Type B - male
Thunderbolt 3 / USB 2.0
USB-C cable
Jacket Material
PVC
American Wire Gauge (AWG)
22/30
Plated Connector
Nickel
Length
50 cm
28 g
Connector
24 pin USB-C - male
Thunderbolt 3 / USB 2.0, RoHS, WEEE
Length: 50cm
Price Range Ex VAT: 0 - 50
