StarTech.com 0.5m USB 2.0 C to A Cable M/M
Quicklinx: CTWCWS00 Mfr#: USB2AC50CM
Length: 50cm
31 in stock
£5.68 ex VAT
£6.81 inc VAT
Connect your USB Type-C devices to your computer, with reduced clutter. This USB-C to USB-A cable makes it easy to charge and sync USB Type-C mobile devices using the USB-A port on your computer or a standard USB-A wall charger, car charger or power bank.
This non-standard 0.5-meter cable is great for close-range connections to charge and sync your USB Type-C mobile devices from your laptop.
You can also use the cable to charge your USB-C devices from a USB-A wall charger, car charger or power bank. It's the ideal cable for commuters, for in-car use or to reduce clutter when syncing with your laptop.
Replace the USB-C charging cable that came with your device or keep one as a spare in your laptop bag, backpack or other carrying case.
StarTech.com 0.5m USB C to USB A Cable - M/M - USB 2.0 - USB cable - 50 cm
USB cable
Double shielded
Sync and charge
Length
50 cm
Connector
4 pin USB Type A - male
Connector (Second End)
24 pin USB-C - male
USB / USB 2.0
P/N: DKT30CVAGPD
USB cable
Double shielded
Shielding Material
Jacket Material
PVC
American Wire Gauge (AWG)
22/30
Plated Connector
Nickel
Sync and charge
Length
50 cm
23 g
Connector
24 pin USB-C - male
USB / USB 2.0, RoHS, WEEE
P/N: DKT30CVAGPD
CTWC StarTech.com 1m USB 2.0 USB-C to USB-A Cable In Stock £7.03
CTWC StarTech.com 6ft USB-C to A Cable - USB 2.0 In Stock £8.93
CTWC StarTech.com 4m USB 2.0 C to A Cable M/M In Stock £14.66
CTWC StarTech.com 0.5m USB 2.0 C to A Cable M/M In Stock £5.68
CTWC StarTech.com 1m USB A to C Cable - USB 2.0 In Stock £7.33
Length: 50cm
Price Range Ex VAT: 0 - 50
