StarTech.com 0.5m Short DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k
Quicklinx: 7RPMWS00 Mfr#: DISPL50CM
Create high-resolution 4k x 2k connections with HBR2 support between your DisplayPort-equipped devices, with reduced clutter. The DISPL50CM 0.5m/50cm DisplayPort 1.2 Cable with latches provides a secure, connection between your DisplayPort-equipped devices and is capable of providing higher performance than either HDMI or dual link DVI.
The DP cable supports high resolutions of up to 4k x 2k (3840 x 2160) @ 60Hz with a maximum HBR2 bandwidth of 21.6 Gbps. The cable also supports Multi-Stream (MST) for daisy chaining multiple monitors and provides optional audio support.
The short 50cm DisplayPort cable is perfect for mobile applications, such as connecting your laptop to a monitor and it provides a portable solution that makes it perfect for carrying as a laptop accessory.
StarTech.com 0.5m Short DisplayPort 1.2 Cable with Latches DisplayPort 4k - DisplayPort cable - 50 cm
DisplayPort cable
Shielded
Latched
Length
50 cm
Connector
DisplayPort - male
Connector (Second End)
DisplayPort - male
RoHS
DisplayPort cable
Shielded
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Latched
Length
50 cm
Connector
20 pin DisplayPort - male
RoHS
7RPM StarTech.com 5m Long DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £27.29
7RPM StarTech.com 2m DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £12.31
7RPM StarTech.com 1m DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £10.22
7RPM StarTech.com 3m DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £24.83
7RPM StarTech.com 7m DisplayPort Cable with Latches - M/M In Stock £63.03
