StarTech.com 0.5m Premium 4K HDMI Cable
Quicklinx: D72MWS00 Mfr#: HDMM50CMP
Type: Cable
Length: 50cm
More than 50 in stock
£7.97 ex VAT
£9.56 inc VAT
Create feature-rich HDMI connections that are certified to be error-free. This 0.5-meter High Speed HDMI cable has been tested in accordance with the Premium HDMI Cable Certification Program. This ensures it's able to deliver the newest technical features that the latest HDMI specifications have to offer, including enhanced resolutions and protection against EMI interference.
Each of the certified Premium High Speed HDMI Cables is labeled with unique anti-counterfeiting authentication, so you can be confident that you have received a genuine certified cable.
The cable supports resolutions of up to 4K@60Hz (3840x2160p) and bandwidths of up to 18Gbps. It also supports HDR (High Dynamic Range) for higher contrast ratio and vivid colors.
With higher resolutions, increased speeds, and sharper images, you can expect an enhanced video experience. The cable is guaranteed to provide the very best HDMI capabilities available today. It's the perfect cable for creating dependable home theater connections or providing lifelike digital signage.
Plus, the cable also supports up to 32 uncompressed digital audio channels to provide crystal-clear sound. The cable is also backward compatible with previous HDMI specifications and will work with all of your existing HDMI devices.
The cable has undergone rigorous compliance testing and is certified by an HDMI Authorized Test Center. This gives you the assurance that the cable will deliver the high-bandwidth enabled features you need. An EMI test is also performed to ensure the cable minimizes interference with wireless signals.
The cable delivers dual video streams so that you can view two videos simultaneously on the same display. Your display must support Multi-View in order to take advantage of dual video streams.
StarTech.com Premium Premium Certified High Speed HDMI 2.0 Cable with Ethernet - 1.5ft 0.5m - HDR 4K 60Hz - 20 inch Short HDMI Male to Male Cord (HDMM50CMP) - HDMI with Ethernet cable - 50 cm
Cable
American Wire Gauge (AWG)
34
Length
50 cm
Connector
HDMI - male
Connector (Second End)
HDMI - male
HDMI CEC support (Consumer Electronics Control), 4K format support, HDR support
Cable Type
34
Jacket Material
PVC
Shielding Material
Length
50 cm
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
RoHS, WEEE, ITU-R BT.2020
100 g
D72M StarTech.com 1m 3ft Premium HDMI 2.0 Cable In Stock £8.22
D72M StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £11.32
D72M StarTech.com 0.5m Premium 4K HDMI Cable In Stock £7.97
Type: Cable
Length: 50cm
Price Range Ex VAT: 0 - 50
