StarTech.com 0.5m Mini USB Cable - A to Up Angle Mini B
Quicklinx: 91F4WS00 Mfr#: USBAMB50CMU
Connect your portable Mini USB devices at short distances, with the cable kept out of the way. The USBAMB50CMU 50cm USB to Up Angle Mini USB Cable provides a high quality connection between your Mini USB 2.0 mobile devices (smartphones, GPS, digital cameras, portable hard drives, etc.) and your PC or Mac computer, for everyday tasks such as charging, data synchronization or file transfers.
The up-angled Mini USB connector allows you to access your Mini USB devices, while keeping the cable out of the way, and stress away from the port.
Perfect for close-range device connections, a shorter mini USB cables provide a portable solution that makes them perfect for carrying as an accessory for your tablet or laptop.
As an alternative, StarTech.com also offers a 0.5m USB to Down Angle Mini USB Cable (USBAUB50CMD), which provides the same convenience as this up-angled cable, but allows you to connect to your Mini USB device from the opposite direction.
StarTech.com 0.5m Mini USB Cable - A to Up Angle Mini B - USB cable - USB to mini-USB Type B - 50 cm
USB cable
Double shielded
90° connector
Length
50 cm
Connector
4 pin USB Type A - male
Connector (Second End)
Mini-USB Type B - male
USB cable
Double shielded
American Wire Gauge (AWG)
28
Plated Connector
Nickel
90° connector
Length
50 cm
Connector
RoHS
