StarTech.com 0.5m Dock Connector to USB Cable ASUS Transformer Pad and Eee Pad Transformer / Slider
Quicklinx: 94B0WS00 Mfr#: USB2ASDC50CM
Length: 50cm
Select:
£7.61 ex VAT
£9.13 inc VAT
Charge your ASUS Transformer/Slider Tablet with reduced cable clutter. The USB2ASDC50CM ASUS Transformer USB Cable enables close-range connections to your PC or Mac computer or to your laptop, for transferring data and charging your ASUS Eee Pad Transformer (TF101, Prime, etc.), ASUS Transformer Pad (Infinity, etc.) or ASUS Eee Pad Slider.
The short 1.5ft/0.5m cable minimizes the clutter of excess cable and provides a portable solution that makes it perfect for carrying as a tablet accessory.
For convenience, this versatile ASUS tablet cable can be connected to a computer USB port for data transfers while you are working. Or you can connect the cable to the USB power adapter which was supplied with your ASUS Pad, for simple charging from an available (wall) power outlet.
This ASUS Transformer USB Cable is designed and constructed for maximum durability, making it a dependable replacement for damaged or misplaced data / charging cables.
StarTech.com 50cm Dock Connector to USB Cable ASUS Transformer Pad Eee Pad - charging / data cable - 50 cm
Cable
Charging / data cable
Double shielded
American Wire Gauge (AWG)
24/30
Length
50 cm
Connector
ASUS 40-pin Dock Connector - male
Connector (Second End)
USB - male
ASUS Eee Pad Slider; Eee Pad Transformer; Transformer Pad
Cable Type
Double shielded
24/30
Jacket Material
PVC
Shielding Material
Length
50 cm
Plated Connector
Nickel
Recommended Use
Tablet
Connector
4 pin USB Type A - male
RoHS
Limited warranty - lifetime
ASUS Eee Pad Slider , ASUS Eee Pad Transformer , ASUS Transformer Pad
94B0 StarTech.com 3m Dock Connector to USB Cable for ASUS Transformer Pad and Eee Pad Transformer Slider In Stock £8.21
94B0 StarTech.com 0.5m Dock Connector to USB Cable ASUS Transformer Pad and Eee Pad Transformer / Slider In Stock £7.61
Length: 50cm
Price Range Ex VAT: 0 - 50
