Product
StarTech.com 0.5m (20in) Short Right Angle Apple 30-pin Dock Connector to USB Cable
Quicklinx: 8D6WWS00 Mfr#: USB2ADC50CMR
Length: 50cm
15 in stock
£7.81 ex VAT
£9.37 inc VAT
Charge or Sync your iPhone, iPod, or iPad with reduced clutter and the cable out of the way. The USB2ADC50CMR USB cable for iPhone, iPod and iPad (0.5m) features a right-angled Apple (30-pin) Dock Connector which positions the cable in such a way that it allows you to easily access your iOS-enabled mobile digital device in both portrait and landscape mode, even while charging.
Plus, the USB to iPhone cable features a uniquely constructed stepped Apple Dock Connector, designed by StarTech.com. Unlike a regular connector, the exclusive stepped connector plugs into your iPhone, iPod or iPad, even when inside a protective case, avoiding the inconvenience of having to constantly remove the cover for every charge/sync.
This durable cable is Apple MFi certified.
As an alternative, StarTech.com also offers a 0.5m Left Angle Apple 30-pin Dock Connector to USB Cable (USB2ADC50CML), which provides the same convenience as this right-angled cable, but allows you to connect to your iPhone, iPod or iPad from the opposite direction.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 0.5m 30-pin Dock to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
StarTech.com 20in Right Angle Apple 30-pin Dock to USB Cable iPhone iPad - charging / data cable - 50 cm
Cable
Charging / data cable
Shielded
American Wire Gauge (AWG)
28
Length
50 cm
White
Connector
USB - male
Connector (Second End)
Apple Dock - male
Angled connector
Apple iPad (3rd generation); iPad 1; 2; iPhone 3G, 3GS, 4, 4S; iPod (4G, 5G); iPod classic; iPod mini; iPod nano (1G, 2G, 3G, 4G, 5G, 6G); iPod touch (1G, 2G, 3G, 4G)
Cable Type
Charging / data cable - angled connector
Shielded
28
Jacket Material
PVC
Shielding Material
Length
50 cm
Plated Connector
Nickel
White
Connector
4 pin USB Type A - male
Apple Dock connector - male
RoHS, MFI
Limited warranty - lifetime
Apple iPad (3rd generation) , Apple iPad 1 , Apple iPad 2 , Apple iPhone 3G, 3GS, 4, 4S , Apple iPod (4G, 5G) , Apple iPod classic , Apple iPod mini , Apple iPod nano (1G, 2G, 3G, 4G, 5G, 6G) , Apple iPod touch (1G, 2G, 3G, 4G)
Length: 50cm
Price Range Ex VAT: 0 - 50
