Charge or Sync your iPhone, iPod, or iPad with reduced clutter and the cable out of the way. The USB2ADC50CML USB cable for iPhone, iPod and iPad (0.5m) features a left-angled Apple (30-pin) Dock Connector which positions the cable in such a way that it allows you to easily access your iOS-enabled mobile digital device in both portrait and landscape mode, even while charging.
Plus, the USB to iPhone cable features a uniquely constructed stepped Apple Dock Connector, designed by StarTech.com. Unlike a regular connector, the exclusive stepped connector plugs into your iPhone, iPod or iPad, even when inside a protective case, avoiding the inconvenience of having to constantly remove the cover for every charge/sync.
This durable cable is Apple MFi certified.
As an alternative, StarTech.com also offers a 0.5m Right Angle Apple 30-pin Dock Connector to USB Cable (USB2ADC50CMR), which provides the same convenience as this left-angled cable, but allows you to connect to your iPhone, iPod or iPad from the opposite direction.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 0.5m 30-pin Dock to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
- StarTech.com 0.5m Left Angle Apple 30pin Dock to USB Cable iPhone iPad - charging / data cable - 50 cm
- Cable
- Charging / data cable
- Technology
- Shielded
- American Wire Gauge (AWG)
- 28
- Length
- 50 cm
- White
- Connector
- USB - male
- Connector (Second End)
- Apple Dock - male
- Angled connector
- Limited lifetime warranty
- Designed For
- Apple iPod (4G, 5G); iPod classic; iPod mini
- Cable Type
- Charging / data cable angled connector
- Technology
- Shielded
- 28
- Jacket Material
- PVC
- Shielding Material
- Aluminum mylar foil with braid
- Length
- 50 cm
- Plated Connector
- Nickel
- White
- Connector
- 4 pin USB Type A - male
- Apple Dock connector - male
- RoHS, MFI
- Limited warranty - lifetime
- Designed For
- Apple iPod (4G, 5G) , Apple iPod classic , Apple iPod mini
