StarTech.com 0.3m SATA Extension Cable
Quicklinx: 84P4WS00 Mfr#: SATAEXT30CM
Length: 30cm
49 in stock
£6.56 ex VAT
£7.87 inc VAT
Extend SATA Data Connections by up to 30cm (12in). The SATAEXT30CM 0.3-meter (30cm) SATA Data Extension Cable enables you to extend the reach between internal SATA drive connections by up to 30 cm (11.81 in).
The extension simplifies drive installation by overcoming typical connection limitations, and it reduces the risk of damage to the drive or motherboard SATA connectors by eliminating the need to strain or stretch the cable in order to make the necessary connection.
StarTech.com 0.3m SATA Extension Cable - 30cm 7 pin SATA Extension - 7 pin SATA Extension Cable - 7 pin SATA Extension cord - SATA extension cable - 30 cm
Interface Speed
Serial ATA 150/300/600
Length
30 cm
Connector
7 pin Serial ATA - plug
Connector (Second End)
7 pin Serial ATA - receptacle
Red
P/N: SATA18RA1
Storage Cable Type
Interface Speed
American Wire Gauge (AWG)
26
Length
30 cm
Red
Connector
RoHS
P/N: SATA18RA1
84P4 StarTech.com 20in Slimline SATA Extension Cable In Stock £9.30
84P4 StarTech.com 12in 22 Pin SATA Power and Data Extension Cable In Stock £6.04
84P4 StarTech.com 0.3m SATA Extension Cable In Stock £6.56
Length: 30cm
Price Range Ex VAT: 0 - 50
