Create Ultra HD connections between your High Speed HDMI-equipped devices, with reduced clutter. The HDMM30CM 30cm High Speed HDMI cable enables close-range connections of your HDMI-enabled devices, for situations where a longer cable would create clutter.
Plus, this short HDMI cable provides a portable solution that makes it perfect for carrying as a mobile accessory. When used with an HDMI to Micro or Mini HDMI adapter such as our HDMI 2-in-1 T-adapter, you can connect mobile devices such as your Smartphone, or Tablet to an HD display, or your Digital Camera to a laptop.
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
StarTech.com High Speed HDMI digital video and audio cables are expertly designed and constructed of only top quality materials to ensure high quality, high-definition performance. The HDMI standard combines high bandwidth video and multi-channel digital audio into a single cable, and provides crystal clear image resolution.
- StarTech.com 0.3m 1ft Short High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI M/M - 30cm HDMI 1.4 Cable - Audio/Video Gold-Plated (HDMM30CM) - HDMI cable - 30 cm
- Cable
- HDMI cable
- Technology
- Double shielded
- American Wire Gauge (AWG)
- 28
- Length
- 30 cm
- Black
- Connector
- HDMI - male
- Connector (Second End)
- HDMI - male
- Limited lifetime warranty
- Cable Type
- HDMI cable
- Technology
- Double shielded
- 28
- Jacket Material
- PVC
- Shielding Material
- Aluminum mylar foil with braid
- Length
- 30 cm
- Plated Connector
- Gold
- Black
- Connector
- 19 pin HDMI Type A - male
- RoHS
- Limited warranty - lifetime
