StarTech.com 0.3m (1ft) Coiled Black Apple 8-pin Lightning Connector to USB Cable iPhone iPodiPad
Quicklinx: 93HKWS00 Mfr#: USBCLT30CMB
Colours:
Charge your Apple Lightning-equipped devices with reduced clutter, in your car with this 1ft coiled cable. The USBCLT30CMB Black Coiled Lightning to USB Cable for iPhone, iPod, and iPad can comfortably be stretched out to up to 0.3m/1ft to reach your mobile device and when compressed can be tucked out of way, to provide simple, tidy connections - great for charging in your car (requires USB charge port).
Colored to suit your black mobile devices, this Lightning to USB cable provides a reliable solution for both syncing and charging and provides a compact solution that makes it perfect for carrying as an iPad or iPhone accessory.
Plus, the reversible 8-pin Lightning connector can be plugged into your iOS-enabled device with either side facing up, meaning there is no wrong way of inserting the cable into the device.
This durable cable is Apple MFi certified.
StarTech.com 1ft Coiled Lightning to USB Cable - Black - Apple 8 Pin Lightning Charger Cable for Your iPhone / iPad / iPod (USBCLT30CMB) - Lightning cable - Lightning / USB - 30 cm
Cable
Shielded
American Wire Gauge (AWG)
24/28
Length
30 cm
Connector
Lightning - male
Connector (Second End)
USB - male
Coiled
Cable Type
Lightning cable
Interface Supported
Lightning / USB
Shielded
24/28
Jacket Material
PVC
Shielding Material
Length
30 cm
Plated Connector
Nickel
Coiled
Connector
Apple Lightning - male
4 pin USB Type A - male
RoHS
