StarTech.com 0.3m (11in) Short White Apple 8-pin Lightning Connector to USB Cable iPhone iPod iPad
Quicklinx: 8ZD3WS00 Mfr#: USBLT30CMW
Colours:
Charge and Sync your Apple Lightning-equipped devices with reduced clutter. The USBLT30CMW 30cm White Lightning to USB Cable for iPhone, iPod, and iPad provides a reliable solution for charging and syncing your newer generation Apple mobile devices with your PC or Mac computer, through an available USB port.
Perfect for close-range device connections, the shorter Lightning USB cables provide a portable solution that makes them perfect for carrying as a laptop accessory. Plus, the reversible 8-pin Lightning connector can be plugged into your iOS-enabled device with either side facing up, meaning there is no wrong way of inserting the cable into the device.
This durable cable is Apple MFi certified.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 30cm Lightning to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
StarTech.com 0.3m (11in) Short White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad - Charge and Sync Cable (USBLT30CMW) - Lightning cable - Lightning / USB - 30 cm
Cable
Double shielded
American Wire Gauge (AWG)
24/28
Length
30 cm
White
Connector
Lightning - male
Connector (Second End)
USB - male
Sync and charge
P/N: MST30C2DPPD, ST4200MINI2, ST4200MINIC, TB3DK2DHV, TB3DK2DHVUE, TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE, USB2PCARBK, USB2PCARBKS, USB3VDOCKD, USBLT2PCARW, USBUB2PCARB
Cable Type
Lightning cable
Interface Supported
Lightning / USB
Double shielded
24/28
Jacket Material
PVC
Shielding Material
Length
30 cm
Plated Connector
Nickel
Sync and charge
White
Connector
Apple Lightning - male
4 pin USB Type A - male
RoHS, MFI
8ZD3 StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub In Stock £99.33
8ZD3 StarTech.com 6 Port USB 3.0 / USB 2.0 Combo Hub with 2A Charging Port – 2x USB 3.0 & 4x USB 2.0 In Stock £44.71
8ZD3 StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad In Stock £15.34
8ZD3 StarTech.com 2m (6ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad In Stock £16.73
8ZD3 StarTech.com 4 Port USB 3.0 Hub plus 3 Dedicated USB Charging Ports (2 x 1A & 1 x 2A) In Stock £57.29
8ZD3 StarTech.com 3m (10ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad In Stock £21.43
8ZD3 StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black In Stock £51.70
8ZD3 StarTech.com Dual Port Car Charger with Apple 8-pin Lightning Connector and USB 2.0 Port In Stock £26.99
8ZD3 StarTech.com USB Wall Charger 17W / 3.4A x2 In Stock £15.45
8ZD3 StarTech.com 7 Port USB 3.0 Hub Desktop In Stock £71.57
8ZD3 StarTech.com 7 Port Industrial USB 3.0 Hub In Stock £111.58
8ZD3 StarTech.com 2x USB Wall Charger 17W / 3.4A In Stock £15.56
8ZD3 StarTech.com 10 Port Industrial USB 3.0 Hub In Stock £131.83
8ZD3 StarTech.com 10-Pt USB 3.0 Hub w/ Charging In Stock £66.89
8ZD3 StarTech.com 7-Pt USB 3.0 Hub + Charge Pts In Stock £60.86
8ZD3 StarTech.com 2x USB Car Charger 24W / 4.8A In Stock £12.35
8ZD3 StarTech.com 2x USB Car Charger 24W / 4.8A In Stock £11.54
8ZD3 StarTech.com 4 Port USB 3.0 Hub with USB C In Stock £44.99
8ZD3 StarTech.com 4PT USB 3.0 Hub - Charge Port In Stock £34.39
