StarTech.com 0.3m (11in) Short White Apple 8-pin Lightning Connector to USB Cable iPhone iPod iPad
Quicklinx: 8ZD3WS00 Mfr#: USBLT30CMW
Length: 30cm
Colours:
£12.29 ex VAT
£14.74 inc VAT
Express delivery Order within the next 22 hours for delivery on Wednesday
Charge and Sync your Apple Lightning-equipped devices with reduced clutter. The USBLT30CMW 30cm White Lightning to USB Cable for iPhone, iPod, and iPad provides a reliable solution for charging and syncing your newer generation Apple mobile devices with your PC or Mac computer, through an available USB port.
Perfect for close-range device connections, the shorter Lightning USB cables provide a portable solution that makes them perfect for carrying as a laptop accessory. Plus, the reversible 8-pin Lightning connector can be plugged into your iOS-enabled device with either side facing up, meaning there is no wrong way of inserting the cable into the device.
This durable cable is Apple MFi certified.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 30cm Lightning to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
StarTech.com 11in Short White Apple 8pin Lightning to USB Cable iPhone iPad - Lightning cable - Lightning / USB - Lightning to USB - 30 cm
Cable
Double shielded
American Wire Gauge (AWG)
24/28
Length
30 cm
White
Connector
Lightning - male
Connector (Second End)
USB - male
Sync and charge
Apple iPad mini; iPad with Retina display (4th generation); iPhone 5; iPod nano (7G); iPod touch (5G)
Cable Type
Lightning cable
Interface Supported
Lightning / USB
Double shielded
24/28
Jacket Material
PVC
Shielding Material
Length
30 cm
Plated Connector
Nickel
Sync and charge
White
Connector
Apple Lightning - male
4 pin USB Type A - male
RoHS, MFI
Apple iPad mini , Apple iPad with Retina display (4th generation) , Apple iPhone 5 , Apple iPod nano (7G) , Apple iPod touch (5G)
Length: 30cm
Price Range Ex VAT: 0 - 50
