StarTech.com 0.3m (11in) Short Black Apple 8-pin Lightning Connector to USB Cable iPhone iPod iPad
Quicklinx: 8ZD2WS00 Mfr#: USBLT30CMB
Length: 30cm
Colours:
16 in stock
£12.44 ex VAT
£14.92 inc VAT
Charge and Sync your Apple Lightning-equipped devices with reduced clutter. The USBLT30CMB 30cm Black Lightning to USB Cable for iPhone, iPod, and iPad is colored to suit black mobile devices and provides a reliable solution for charging and syncing your newer generation Apple mobile devices with your PC or Mac computer, through an available USB port.
Perfect for close-range device connections, the shorter Lightning USB cables provide a portable solution that makes them perfect for carrying as a laptop accessory. Plus, the reversible 8-pin Lightning connector can be plugged into your iOS-enabled device with either side facing up, meaning there is no wrong way of inserting the cable into the device.
This durable cable is Apple MFi certified.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 30cm Lightning to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
StarTech.com 0.3m (11in) Short Black Apple® 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad - Charge and Sync Cable (USBLT30CMB) - Lightning cable - Lightning / USB - 30 cm
Cable
Double shielded
American Wire Gauge (AWG)
24/28
Length
30 cm
Connector
Lightning - male
Connector (Second End)
USB - male
Sync and charge
P/N: ST4CU424, ST4CU424EU, ST4CU424UK, ST8CU824, TB3DK2DHV, TB3DK2DHVUE, TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE, USBAUBSCHM
Cable Type
Lightning cable
Interface Supported
Lightning / USB
Double shielded
24/28
Jacket Material
PVC
Shielding Material
Length
30 cm
Plated Connector
Nickel
Sync and charge
Connector
Apple Lightning - male
4 pin USB Type A - male
RoHS, MFI
8ZD2 StarTech.com 1m (3ft) Black Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad In Stock £11.86
8ZD2 StarTech.com 2m (6ft) Long Black Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad In Stock £12.81
8ZD2 StarTech.com 0.3m (11in) Short Black Apple 8-pin Lightning Connector to USB Cable iPhone iPod iPad In Stock £12.44
Length: 30cm
Price Range Ex VAT: 0 - 50
