StarTech.com 0.3m (11in) Short Apple 30-pin Dock Connector to USB Cable with Stepped Connector
Quicklinx: 8Y6KWS00 Mfr#: USB2ADC30CM
Charge or Sync your iPhone, iPod, or iPad with reduced clutter. The USB2ADC30CM 0.3m Apple (30-pin) Dock Connector to USB cable for iPhone, iPod and iPad enables close-range syncing and charging of your iOS-enabled mobile digital devices, for situations where a longer cable would create clutter. Plus, the shorter cable design provides a portable solution that makes it perfect for carrying as a laptop accessory.
The USB to iPhone cable features a uniquely constructed stepped Apple Dock Connector, designed by StarTech.com. Unlike a regular connector, the exclusive stepped connector plugs into your iPhone, iPod or iPad, even when inside a protective case, avoiding the inconvenience of having to constantly remove the cover for every charge/sync.
This durable cable is Apple MFi certified.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 0.3m 30-pin Dock to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
StarTech.com 11in Short Apple 30-pin Dock to USB Cable for iPhone iPad - charging / data cable - 30 cm
Cable
Charging / data cable
Double shielded
American Wire Gauge (AWG)
28
Length
30 cm
White
Connector
USB - male
Connector (Second End)
Apple Dock - male
Apple iPod (4G, 5G); iPod classic; iPod mini
Cable Type
Double shielded
28
Jacket Material
PVC
Shielding Material
Length
30 cm
Plated Connector
Nickel
White
Connector
4 pin USB Type A - male
Apple Dock connector - male
RoHS, MFI
Limited warranty - lifetime
Apple iPod (4G, 5G) , Apple iPod classic , Apple iPod mini
