Xperia XZ perfects the fundamentals of a great smartphone. Packed with innovations in technology, it boasts a photo-pro's camera, an intelligent battery and smart features, that adapt to you. And it's all delivered in a stunning, evolved design.
The camera with higher precision
Xperia XZ comes loaded with the advanced photography technologies you recognize. There is a triple image sensing technology, added to analyze, adapt and capture perfect shots in challenging conditions. -
Capture moving objects in any light without blur
Life's amazing subjects are rarely still for long. Xperia XZ allows you to capture even moving objects - before the moment passes you by. Bringing together the power of an imaging sensor and a laser autofocus sensor, you can freeze movement in the sharp detail, even when the light is low. -
True-to-life colors in any light
The RGBC-IR sensor delivers incredibly accurate colors, whether you're in bright sun or indoors. It analyzes and adapts to any light, reproducing colors just as you see them. So your pictures don't need any extra punch before sharing. -
Perfectly tailored to life
Xperia XZ's uncluttered design is meant to fit seamlessly into your life. The soft, rounded form is comfortable to hold, while the stunning colors are designed to suit your style. -
Water-resistant design
Sony's water-resistant design takes the worry out of a little wet. Xperia XZ is built to withstand the splashes, that are a part of everyday life. So you can relax about sudden spills or unexpected showers. -
The phone, that gets smarter every day
Xperia XZ is the smartphone, that gets smarter and more personal as you use it. It learns and adapts based on how you use your phone, giving you the perfect smartphone experience to date. -
Adaptive charging
Charging can take a toll on your battery, but Xperia XZ uses intelligent charging to prevent battery decline. It learns your charging patterns and adapts to them, resulting in longer battery lifespan.
- Sony XPERIA XZ - mineral black - 4G smartphone - 32 GB - GSM
- Product Type
- 4G smartphone
- Manufacturer Model Number
- F8331
- Display
- LCD display - 1920 x 1080 pixels - 5.2" - IPS - Corning Gorilla Glass (scratch resistant glass)
- FM radio
- Processor
- Qualcomm MSM8996 (quad-core) - 64-bit
- Graphics Accelerator
- Qualcomm ADRENO 530
- Memory
- RAM 3 GB / 32 GB
- Supported Memory Card
- microSDXC slot - up to 256 GB
- Operating System
- Android 6.0.1 (Marshmallow)
- Main Camera
- 23 Megapixel - Exmor RS 120 mm - f/2.0 - focus: automatic laser auto focus: - laser focus
- Front Camera
- 13 Megapixel Exmor RS - wide-angle lens - f/2.0
- Service Provider
- Not specified
- SIM Card
- Nano SIM
- Wireless Interface
- NFC, Wi-Fi 5, Bluetooth
- Security Devices
- Fingerprint reader
- Messaging Services
- Google+ Hangouts, SMS, MMS
- Connectors
- 3.5 mm headset jack, USB-C
- Talk Time
- Up to 1050 minutes
- Standby Time
- Up to 610 hours
- Protection
- Dustproof, waterproof
- Mineral black
- 72 mm x 8.1 mm x 146 mm
- 161 g
- Specific Absorption Rate (SAR)
- 0.85 W/kg (head) , 1.2 W/kg (body)
- Product Type
- Smartphone
- F8331
- Form Factor
- Touch
- Protection
- Integrated Components
- FM radio
- 72 mm
- 8.1 mm
- 146 mm
- 161 g
- Body Colour
- Mineral black
- SAR Value
- 1.2 W/kg (body), 0.85 W/kg (head)
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 4G
- Service Provider
- Not specified
- Operating System
- Navigation
- A-GPS, GLONASS, BeiDou
- SIM Card Type
- Nano SIM
- Input Device
- Multi-touch, capacitive
Messaging & Internet
- Supported Email Protocols
- POP3, IMAP4
- Supported Social Networks and Blogs
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+, LTE
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 19, Band 20, Band 26, Band 28, Band 29, Band 32, Band 38, Band 39, Band 40, Band 41
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 upper, FDD 800 DD, FDD 850+, FDD 700 APT, FDD 700d, FDD 1500 L, TDD 2600, TDD 1900, TDD 2300, TDD 2500
- NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 4.2
- WLAN Security
- WEP, WPA, WPA2, TKIP, AES, EAP SIM, EAP-TTLS/MSCHAPv2, EAP-AKA, EAP-TLS, PEAPv0/EAP-MSCHAPv2, PEAPv1/EAP-GTC
- Bluetooth Profiles
- HFP, HSP, OPP, PAN, SPP, GAP, A2DP, AVRCP, HID, GAVDP, PBAP, MAP, DIP, GATT, HOGP
Phone Features
- Phone Functions
- Speakerphone, call timer, conference call, flight mode, vibrating alert
- Sensors
- Accelerometer, ambient light sensor, proximity sensor, digital compass, barometer, magnetometer, gyro sensor, Time of Flight (ToF), geomagnetic sensor
- Security Devices
- Additional Features
- TTY compatible, Radio Data Service (RDS), DLNA Certified, Text-to-Speech (text recognition), sharing media via DLNA, Screen capture, intelligent typing (SWIFTKEY), Wi-Fi Miracast, battery STAMINA mode, Glove mode, TRILUMINOS display, X-Reality engine, Clear Audio+, Clear Bass, Dynamic normaliser, Digital Noise Cancelling (DNC), Hi-Res Audio, Low power audio playback, Smart backlight control, Wi-Fi Passpoint, S-Force Front surround, Read Mode, Alarm Clock, PS4 Remote Play, Noise suppression, Smart cleaner, Qnovo Adaptive Charging, Battery Care
Media Player
- Supported Digital Audio Standards
- WAV, WMA, AAC, AIFF, ASF, PCM, Ogg Vorbis, AMR, MP3, FLAC, AAC-LC, XMF, AAC +, eAAC+, MKA, MIDI, M4A, apt-X, DSF, DSDIFF, DSD, LDAC, MXMF, AWB, IMY, RTTTL, RTX, OTA, ALAC, OPUS
- Supported Digital Video Standards
- MKV, AVI, XviD, MPEG-4, MPEG-2, 3GP, H.264, H.263, M4V, TS, WebM, VP8, 3GP2, H.265
- Sound Enhancements
- 3D surround sound (VPT)
- Qualcomm
- Processor Number
- MSM8996
- Processor Core Qty
- Quad-core
- 64-bit Architecture
Graphics System
- RAM
- 3 GB
- Internal Memory Capacity
- 32 GB
- User Memory
- 20 GB
- Supported Flash Memory Cards
- microSDHC, microSDXC - up to 256 GB
Front Camera
- Sensor Resolution
- 13 Megapixel
- Sensor Name
- Sony Exmor RS sensor
- Lens Type
- Wide-angle lens
- Lens Aperture
- F/2.0
- Video Resolutions
- 1920 x 1080 (1080p)
Main Camera
- Sensor Resolution
- 23 Megapixel
- Sensor Name
- Lens Aperture
- F/2.0
- Min Focal Length
- 120 mm
- Focus Adjustment
- Automatic
- Laser Auto Focus
- Digital Zoom
- 8x
- Special Effects
- Night Scene, Creative effect
- Camera Modes
- Red-Eye Reduction, Sweep Panorama, AR Effect mode, SteadyShot, manual mode, Timeshift video, Style Portrait
- Face Detection
- Smile shutter
- HDR Mode
- Auto HDR mode
- Light Source
- LED light
- Video Resolutions
- Quick Launch, Superior Auto, Object tracking, G lens, Scene recognition, BIONZ image processing engine, Sound Photo, Touch Capture, Hand Shutter, Triple sensing technology, Predictive Hybrid Autofocus
Display
- LCD display
- Technology
- IPS
- Diagonal Size
- 5.2"
- Display Resolution
- Display Format
- Full HD
- Colour Depth
- 16.7 million colours
- Enhancement Technology
- Super Vivid mode, Dynamic Contrast Enhancement
- Protection
- 2.5D curved glass
- Connector Type
- Headset jack - mini-phone 3.5mm , USB Type-C - 24 pin USB-C
- Capacity
- 2900 mAh
- Talk Time
- 1050 minutes
- Standby Time
- 610 hours
- Run Time Details
- Talk (GSM): up to 700 min , Standby (GSM): up to 600 hrs , Talk (WCDMA): up to 1050 min , Standby (WCDMA): up to 610 hrs , Standby (LTE): up to 590 hrs , Playback (Music): up to 78 hrs , Playback (video): up to 11 hrs
- IP68, IP65, HAC (Hearing Aid Compatible)
- Included Accessories
- Power adapter
