Sony Xperia XZ - Forest Blue
Quicklinx: CP1LWS00 Mfr#: 1305-1765
  • microSDHC
  • Android
Xperia XZ perfects the fundamentals of a great smartphone. Packed with innovations in technology, it boasts a photo-pro's camera, an intelligent battery and smart features, that adapt to you. And it's all delivered in a stunning, evolved design.
  • The camera with higher precision
    Xperia XZ comes loaded with the advanced photography technologies you recognize. There is a triple image sensing technology, added to analyze, adapt and capture perfect shots in challenging conditions.
  • Capture moving objects in any light without blur
    Life's amazing subjects are rarely still for long. Xperia XZ allows you to capture even moving objects - before the moment passes you by. Bringing together the power of an imaging sensor and a laser autofocus sensor, you can freeze movement in the sharp detail, even when the light is low.
  • True-to-life colors in any light
    The RGBC-IR sensor delivers incredibly accurate colors, whether you're in bright sun or indoors. It analyzes and adapts to any light, reproducing colors just as you see them. So your pictures don't need any extra punch before sharing.
  • Perfectly tailored to life
    Xperia XZ's uncluttered design is meant to fit seamlessly into your life. The soft, rounded form is comfortable to hold, while the stunning colors are designed to suit your style.
  • Water-resistant design
    Sony's water-resistant design takes the worry out of a little wet. Xperia XZ is built to withstand the splashes, that are a part of everyday life. So you can relax about sudden spills or unexpected showers.
  • The phone, that gets smarter every day
    Xperia XZ is the smartphone, that gets smarter and more personal as you use it. It learns and adapts based on how you use your phone, giving you the perfect smartphone experience to date.
  • Adaptive charging
    Charging can take a toll on your battery, but Xperia XZ uses intelligent charging to prevent battery decline. It learns your charging patterns and adapts to them, resulting in longer battery lifespan.
Sony XPERIA XZ - forest blue - 4G smartphone - 32 GB - GSM
4G smartphone
Manufacturer Model Number
F8331
Display
LCD display - 1920 x 1080 pixels - 5.2" - IPS - Corning Gorilla Glass (scratch resistant glass)
FM radio
Qualcomm MSM8996 (quad-core) - 64-bit
Graphics Accelerator
Qualcomm ADRENO 530
RAM 3 GB / 32 GB
Supported Memory Card
microSDXC slot - up to 256 GB
Operating System
Android 6.0.1 (Marshmallow)
Main Camera
23 Megapixel - Exmor RS 120 mm - f/2.0 - focus: automatic laser auto focus: - laser focus
Front Camera
13 Megapixel Exmor RS - wide-angle lens - f/2.0
Service Provider
Not specified
SIM Card
Nano SIM
Wireless Interface
NFC, Wi-Fi 5, Bluetooth
Security Devices
Fingerprint reader
Messaging Services
Google+ Hangouts, SMS, MMS
Connectors
3.5 mm headset jack, USB-C
Talk Time
Up to 1050 minutes
Standby Time
Up to 610 hours
Protection
Dustproof, waterproof
Forest blue
72 mm x 8.1 mm x 146 mm
161 g
0.85 W/kg (head) , 1.2 W/kg (body)
Smartphone
F8331
Touch
Protection
Integrated Components
FM radio
72 mm
8.1 mm
146 mm
161 g
Body Colour
Forest blue
SAR Value
1.2 W/kg (body), 0.85 W/kg (head)
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
4G
Service Provider
Not specified
Operating System
Navigation
A-GPS, GLONASS, BeiDou
SIM Card Type
Nano SIM
Input Device
Multi-touch, capacitive
Messaging & Internet
Messaging Services
Supported Email Protocols
POP3, IMAP4
Supported Social Networks and Blogs
Facebook
Communications
Data Transmission
GPRS, EDGE, HSDPA, HSUPA, HSPA+, LTE
2G Band
850 GSM, 900 GSM, 1800 GSM, 1900 GSM
4G LTE Band
Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 19, Band 20, Band 26, Band 28, Band 29, Band 32, Band 38, Band 39, Band 40, Band 41
4G LTE Frequency
FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 upper, FDD 800 DD, FDD 850+, FDD 700 APT, FDD 700d, FDD 1500 L, TDD 2600, TDD 1900, TDD 2300, TDD 2500
Wireless Interface
NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 4.2
WLAN Security
WEP, WPA, WPA2, TKIP, AES, EAP SIM, EAP-TTLS/MSCHAPv2, EAP-AKA, EAP-TLS, PEAPv0/EAP-MSCHAPv2, PEAPv1/EAP-GTC
Bluetooth Profiles
HFP, HSP, OPP, PAN, SPP, GAP, A2DP, AVRCP, HID, GAVDP, PBAP, MAP, DIP, GATT, HOGP
Phone Features
Phone Functions
Speakerphone, call timer, conference call, flight mode, vibrating alert
Sensors
Accelerometer, ambient light sensor, proximity sensor, digital compass, barometer, magnetometer, gyro sensor, Time of Flight (ToF), geomagnetic sensor
Security Devices
Fingerprint reader
Additional Features
TTY compatible, Radio Data Service (RDS), DLNA Certified, Text-to-Speech (text recognition), sharing media via DLNA, Screen capture, intelligent typing (SWIFTKEY), Wi-Fi Miracast, battery STAMINA mode, Glove mode, TRILUMINOS display, X-Reality engine, Clear Audio+, Clear Bass, Dynamic normaliser, Digital Noise Cancelling (DNC), Hi-Res Audio, Low power audio playback, Smart backlight control, Wi-Fi Passpoint, S-Force Front surround, Read Mode, Alarm Clock, PS4 Remote Play, Noise suppression, Smart cleaner, Qnovo Adaptive Charging, Battery Care
Media Player
Supported Digital Audio Standards
WAV, WMA, AAC, AIFF, ASF, PCM, Ogg Vorbis, AMR, MP3, FLAC, AAC-LC, XMF, AAC +, eAAC+, MKA, MIDI, M4A, apt-X, DSF, DSDIFF, DSD, LDAC, MXMF, AWB, IMY, RTTTL, RTX, OTA, ALAC, OPUS
Supported Digital Video Standards
MKV, AVI, XviD, MPEG-4, MPEG-2, 3GP, H.264, H.263, M4V, TS, WebM, VP8, 3GP2, H.265
Sound Enhancements
3D surround sound (VPT)
Qualcomm
Processor Number
MSM8996
Processor Core Qty
Quad-core
64-bit Architecture
Graphics System
Qualcomm ADRENO 530
RAM
3 GB
Internal Memory Capacity
32 GB
User Memory
20 GB
Supported Flash Memory Cards
microSDHC, microSDXC - up to 256 GB
Front Camera
Sensor Resolution
13 Megapixel
Sensor Name
Sony Exmor RS sensor
Lens Type
Wide-angle lens
Lens Aperture
F/2.0
Video Resolutions
1920 x 1080 (1080p)
Main Camera
Sensor Resolution
23 Megapixel
Sensor Name
Lens Aperture
F/2.0
Min Focal Length
120 mm
Focus Adjustment
Automatic
Laser Auto Focus
Digital Zoom
8x
Special Effects
Night Scene, Creative effect
Camera Modes
Red-Eye Reduction, Sweep Panorama, AR Effect mode, SteadyShot, manual mode, Timeshift video, Style Portrait
Face Detection
Smile shutter
HDR Mode
Auto HDR mode
Light Source
LED light
Video Resolutions
1920 x 1080 (1080p)
Quick Launch, Superior Auto, Object tracking, G lens, Scene recognition, BIONZ image processing engine, Sound Photo, Touch Capture, Hand Shutter, Triple sensing technology, Predictive Hybrid Autofocus
Display
LCD display
IPS
Diagonal Size
5.2"
Display Resolution
1920 x 1080 pixels
Display Format
Full HD
Colour Depth
16.7 million colours
Enhancement Technology
Super Vivid mode, Dynamic Contrast Enhancement
Protection
2.5D curved glass
Connector Type
Headset jack - mini-phone 3.5mm , USB Type-C - 24 pin USB-C
2900 mAh
Talk Time
1050 minutes
Standby Time
610 hours
Run Time Details
Talk (GSM): up to 700 min , Standby (GSM): up to 600 hrs , Talk (WCDMA): up to 1050 min , Standby (WCDMA): up to 610 hrs , Standby (LTE): up to 590 hrs , Playback (Music): up to 78 hrs , Playback (video): up to 11 hrs
IP68, IP65, HAC (Hearing Aid Compatible)
Power adapter
