Sony Xperia XA2 - Pink
Quicklinx: DF7QWS00 Mfr#: 1312-1892
  • microSDHC
  • Android
Take your best shots yet. The 23MP camera features an Exmor RS for mobile sensor and 4K video recording to give you outstanding color and clarity, even in lowlight. The Xperia XA2 has a 5.2" full HD display with a borderless design, taking the screen right to the edge, and a perfect fit for your hand. Unlock with a simple touch thanks to the integrated fingerprint sensor, making sure only you can access your phone. Made with durable Corning Gorilla Glass, the Xperia XA2 display has a quality finish that offers uncompromised clarity.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots:
BT Mobile
  • Capture life's beauty
  • Super wide selfie
    Fit lots of friends and more of the scenery into your selfie with a 120° super wide-angle 8MP camera.
  • Designed to fit your hand
  • One-touch fingerprint sensor
  • Durable Corning Gorilla Glass
  • The right settings for every song
    The Smart Amplifier technology, backed up by ClearAudio+ and Clear Bass fine-tunes your sound so every note is clear.
  • Rich sound quality
    Listen to your music loud and clear with Smart Amplifier technology.
  • Clear and balanced sound
    ClearAudio+ delivers an immersive, enriching audio experience at a single touch.
  • Powerful bass without distortion
    Deep lows and bass notes have more impact with Clear BASS.
  • A battery that's built to last
    Enjoy your smartphone for longer with a high capacity battery. Smart charging technologies help keep your battery healthier for the long term.
  • Packed with the power you need
    Browsing the web or playing games? The Xperia XA2 uses the Qualcomm Snapdragon 630 Mobile Platform for a super-smooth and speedy performance.
  • Learns and adapts to you
    The Xperia XA2 uses smart technology to learn how you use your phone. Then Xperia Actions helps optimize your settings, while Xperia Tips gives you handy hints to get more from your phone.
Sony XPERIA XA2 - pink - 4G - 32 GB - GSM - smartphone
Smartphone 4G
Manufacturer Model Number
H3113
Display
LCD display - 1920 x 1080 pixels - 5.2" - 424 ppi - TFT - Corning Gorilla Glass 4 (scratch resistant glass)
Rear-facing camera, front-facing camera, FM radio
Qualcomm Snapdragon 630 (8-core) - 64-bit
Graphics Accelerator
Qualcomm ADRENO 508
32 GB - RAM 3 GB
Supported Memory Card
microSDXC slot - up to 256 GB
Operating System
Android 8.0 Oreo
Rear Camera
23 Megapixel - Exmor RS - wide-angle lens - 5x optical zoom - 120 mm - f/2.0 - focus: automatic
Front Camera
8 Megapixel Exmor R - wide-angle lens - f/2.4 - focus free
Service Provider
Not specified
SIM Card Type
Nano SIM
SIM Card Qty
Dual-SIM
Wireless Interface
NFC, Wi-Fi, Bluetooth
Security Devices
Fingerprint reader
Messaging Services
SMS, MMS
Connectors
3.5 mm headset jack, USB-C
Talk Time
Up to 2340 minutes
Standby Time
Up to 863 hours
Pink
70 mm x 9.7 mm x 142 mm
171 g
SAR
1.43 W/kg (body) / 1.07 W/kg (head)
1-year warranty
Smartphone
H3113
Touch
Integrated Components
Rear-facing camera, front-facing camera, FM radio, audio player, voice recorder, navigation
70 mm
9.7 mm
142 mm
171 g
Body Colour
Pink
SAR Value
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
4G
Service Provider
Not specified
Operating System
Android 8.0 Oreo
Navigation
GPS, A-GPS, GLONASS
SIM Card Type
Nano SIM
SIM Card Qty
Dual-SIM
Input Device
Multi-touch, capacitive
Messaging & Internet
Messaging Services
SMS, MMS
Supported Email Protocols
POP3, IMAP4
Supported Social Networks and Blogs
Communications
Data Transmission
GPRS, EDGE, HSDPA, HSUPA, HSPA+, LTE
2G Band
GSM 850/900/1800/1900
3G UMTS Band
Band 1, Band 2, Band 5, Band 8
3G UMTS Frequency
2100, 1900, 850, 900
4G LTE Band
Band 1, Band 2, Band 3, Band 5, Band 7, Band 8, Band 20, Band 38
4G LTE Frequency
FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 850, FDD 2600, FDD 900, FDD 800 DD, TDD 2600
Wireless Interface
NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.0
WLAN Security
WEP, WPA, WPA2, TKIP, AES, EAP SIM, EAP-TTLS/MSCHAPv2, EAP-AKA, EAP-TLS, PEAPv0/EAP-MSCHAPv2, PEAPv1/EAP-GTC
Bluetooth Profiles
HFP, HSP, OPP, PAN, SPP, GAP, A2DP, AVRCP, HID, SAP, AVCTP, BNEP, GAVDP, PBAP, MAP, DIP, RFCOMM, GATT, HOGP, AVDP
Phone Features
Phone Functions
Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
Sensors
Accelerometer, ambient light sensor, proximity sensor, pedometer, digital compass, magnetometer, motion sensor, geomagnetic sensor, Significant motion detector
Security Devices
Fingerprint reader
Android Enterprise Recommended
Additional Features
TTY compatible, Text-to-Speech (text recognition), intelligent typing (SWIFTKEY), intelligent typing (Gesture), Wi-Fi Miracast, Screen mirroring, Wi-Fi Passpoint, Alarm Clock, handwriting recognition, Noise suppression, Qnovo Adaptive Charging, Battery Care, Smart Stamina, STAMINA Mode
Media Player
Supported Digital Audio Standards
WAV, AAC, MPEG 1 Audio, MPEG 2 Audio, MPEG 2.5 Audio, Ogg Vorbis, MP3, FLAC, AAC-LC, AAC +, OGG, eAAC+, MIDI, MPEG1 Layer3, apt-X, OTA, MP4, AMR-WB, AMR-NB, 3GPP, apt-X HD, SMF
Supported Digital Video Standards
MPEG-4, 3GP, H.264, H.263, WebM, VP8, VP9, 3GPP, H.264 MP, H.264 HP, H.265 Main
Sound Enhancements
Clear Audio+, Surround sound (VPT)
Processor Core Qty
8-core
64-bit Architecture
Graphics System
Qualcomm ADRENO 508
RAM
3 GB - LPDDR4X SDRAM
Internal Memory Capacity
32 GB
User Memory
24 GB
Supported Flash Memory Cards
microSDHC, microSDXC - up to 256 GB
Front Camera
Sensor Resolution
8 Megapixel
Sensor Size
1/4"
Sensor Name
Sony Exmor R sensor
Lens Type
Wide-angle lens
Lens Aperture
F/2.4
Focus Adjustment
Focus free
Camera Modes
SteadyShot
Video Resolutions
1920 x 1080 (1080p) at 30 fps
Self-timer
Rear Camera
Sensor Resolution
23 Megapixel
Sensor Size
1/2.3"
Sensor Name
Sony Exmor RS sensor
Lens Type
Wide-angle lens
Lens Aperture
F/2.0
Min Focal Length
120 mm
Focus Adjustment
Automatic
Optical Zoom
5
Camera Modes
Slow motion video, SteadyShot, low-light shots
Light Source
LED flash
Video Resolutions
3840 x 2160 (4K), 1920 x 1080 (1080p) at 30 fps
Quick Launch, Quick Capture, Hybrid Auto focus, Touch Capture, Stereo Audio Recording, geotagging, 5x Clear Image Zoom
Display
LCD display
TFT
Diagonal Size
5.2"
Display Resolution
1920 x 1080 pixels
Display Format
Full HD
Pixel Density
424 ppi
Max Brightness
500 cd/m²
Colour Depth
16.7 million colours
Protection
2.5D curved glass, Image Enhance Technology
Connector Type
Headset jack - mini-phone 3.5mm , USB Type-C - 24 pin USB-C
Lithium Ion
3300 mAh
Fast Charging Technology
Qualcomm Quick Charge 3.0
Talk Time
2340 minutes
Standby Time
863 hours
Run Time Details
Talk (GSM): up to 2340 min , Standby (GSM): up to 863 hrs , Talk (3G): up to 1740 min , Standby (3G): up to 991 hrs , Standby (LTE): up to 1185 hrs , Playback (MP3 (via headset)): up to 124 hrs , Playback (Full HD video (H.264)): up to 22 hrs
HAC (Hearing Aid Compatible)
Headset, power adapter, USB-C cable
Limited warranty - 1 year
