Designed for education, the VPL-SW525 WXGA (widescreen) projector provides the perfect teaching tool for glare-less projection in changing light conditions.
The VPL-SW525 WXGA (widescreen) projector with easy installation and multiple media connectivity is an ideal choice for ultra-close projection applications in educational markets.
Maximum 2500 lumens brightness with high, standard and low modes
The VPL-SW525 features three brightness modes for different use - 'High' for naturally white presentations in bright rooms, 'Standard' for everyday use and 'Low' for video in darkened rooms. -
3LCD BrightEra technology
Sony's 0.75 inch BrightEra inorganic TFT 3-LCD panels deliver improved panel light resistance, higher resolution, high brightness and increased panel reliability. -
WXGA widescreen resolution
The VPL-SW525 has a color light output of 2500 ANSI lumens and with a native WXGA (1280 x 800) widescreen resolution panel - perfect for video or presentations direct from a laptop or PC. -
6000 hours lamp life
The new driving scheme reduces gap expansion and brightness gradation. A new cooling system allows for uniformity in the temperature of the glass bulb, preventing the glass from clouding. -
Eco mode key
Users can easily select power-saving Eco Modes. The most energy-efficient mode is accessible through a single button-push, and further adjustments are available through a user-friendly menu system. -
ECO lamp dimming
This projector (if the function is set to on) can reduce power consumption and brightness by 10~15% without user detection during a input image. After a pre-set time, the brightness and power consumption will reduce to 30%. -
ECO picture mute - (Instant off / Instant On)
Picture Mute reduces power consumption down to 30% power usage, saving both cost and lamp hours. This feature can be used in the education market as instant off / instant on in-between class changes avoiding the need to power off completely and then turn back on - which increases power consumption and is less time consuming. -
Digital / HD ready
HMDI input means the VPL-SW535 can accept High Definition digital signals from PC or Video source. -
Automatic keystone adjustment
The projector can detect keystone distortion and correct it automatically. (Note that since this is an electronic correction, it may reduce the picture quality slightly). -
Smart APA (Auto Pixel Alignment)
When a computer is used as a picture source, APA automatically optimizes Phase, Pitch and Shift values. These can also be adjusted manually. -
Auto input search
Auto Input Search detects which input has an incoming signal, and automatically switches to it. This makes it easier for users to set up the projector prior to making a presentation. -
Picture muting / audio muting
If there is a need to blackout the image or turn off the audio from the projector, all it takes is a single button-press on the remote control. One button will mute audio and image at the same time. There is also a separate "mute audio" button for audio-only muting. -
Six picture modes
The VPL-SW535 has six available picture modes for correct picture quality; Dynamic, Standard, Game, Living, Cinema, and Presentation. Six picture mode and 3 brightness mode combined, the user can select most suitable picture / brightness mode according to the picture source and environment for perfect image. -
Audio switcher facility
To avoid the need for a separate audio switcher, the projector can be used to select between two audio sources, routing them via a variable audio output to the room amplification system. -
Picture freeze function
Picture Freeze is useful during presentations, enabling the user to look at other material on their PC's screen without the viewing audience being aware. Freeze the current image, and users can use their PC independently of the display from the projector. -
Digital zoom
Digital Zoomallows you to enlarge a selected area of a computer sourced image you are displaying - up to four times. -
Off and go
At the end of a presentation, you can turn off the power supply to the projector immediately, avoiding a 'power down' cycle. -
Direct power On/Off
With this function, there is no need to go through 'Standby' mode when powering up the projector. The projector can be set to activate as soon as power is applied. -
Filter cleaning at the same time as lamp replacement
The filter only needs to be cleaned when a new lamp is fitted, potentially halving disruption due to maintenance. -
Web control and monitoring / E-mail report
A built-in Web Browser allows the user or AV manager to check a projector status remotely. Power ON/STANDBY, Input / output, Lamp usage (hours) can be controlled. An E-mail address can also be set to notify lamp exchange/replacement or any unexpected problems.
- Sony VPL-SW525 - 3LCD projector - ultra short-throw - white
- 3LCD projector - 720p
- White
- Built-in Devices
- Speaker
- Bundled Services
- 3 years PrimeSupport
- Localisation
- Europe
- Networking
- Ethernet, Fast Ethernet
- Brightness
- 2500 lumens
- Contrast Ratio
- 2500:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Lens
- Ultra short-throw lens
- Lens Shift Direction
- Horizontal, vertical
- Bulb type
- UHP 210 Watt
- Bulb life cycle
- Up to 3000 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video (SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, NTSC 3.58)
- Digital Video Standard
- High-Definition Multimedia Interface (HDMI)
- Video Modes
- 575/50p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 480/60i, 576/50i
- Video Output
- RGB
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 280 Watt
- 38.44 cm x 42.34 cm x 12.25 cm
- 7 kg
- 3-year warranty
- Built-in Devices
- Speaker
- Bundled Services
- Networking
- Ethernet
- Data Link Protocol
- Enclosure Colour
- White
- Localisation
- Europe
Projector
- Brightness
- 2500 lumens
- Brightness (Reduced)
- 1800 lumens
- Contrast Ratio
- 2500:1
- Image Size
- 178 cm - 330 cm
- Throw Ratio
- 0.27 - 0.29:1
- Digital Zoom Factor
- 4x
- Resolution
- WXGA - WXGA (1280 x 800) (native) / 1600 x 1200 (resized)
- 16:10
- Display Format
- 3,072,000 pixels (1280 x 800) x 3
- Max Sync Rate (V x H)
- 93 Hz x 93 kHz
- Bulb type
- UHP 210 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction, lens shift dial (horizontal), lens shift dial (vertical)
- OSD Languages
- Hungarian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese, Korean
- Eco-Mode technology, freeze frame, Picture Muting, Smart APA (Auto Pixel Alignment), Auto Input Search, 3LCD Technology, BrightEra, e-mail alerts, Direct Power On, Direct Power Off
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Zoom Factor
- 1.05x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -5/ +5
- Lens Shift Type
- Manual
- Vertical Lens Shift
- 4% / 4%
- Horizontal Lens Shift
- 2% / 2%
Video Input
- TV System
- SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, NTSC 3.58
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
Video Output
- Analogue Video Signal
- RGB
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- Speakers
- 1 x mixed channel
Input Device
- External
- 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x HDMI input - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 1 x S-video input - 4 pin mini-DIN , 1 x RGB output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 (management)
- Included Accessories
- Remote control
- Mounting Kit
- Included
- UL, C-Tick, cUL, NOM, SABS, SASO, CB, CCC, EMC, IC, PSB, FCC, GOST-R, LVD, KC, KUCAS
- Voltage Required
- 280 Watt
- Power Consumption Operational (Standby)
- 7.5 Watt
- 38.44 cm
- 42.34 cm
- 12.25 cm
- 7 kg
- Limited warranty - parts and labour - 3 years , Limited warranty - lamp - 1 year / 1000 hours
- 0 °C
- 40 °C
- 35 - 85% (non-condensing)
- Sound Emission
- 35 dB
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
