Sony VPL SW525 - LCD projector - 2500 lumens - 1280 x 800
Quicklinx: 919CWS00 Mfr#: VPL-SW525
Designed for education, the VPL-SW525 WXGA (widescreen) projector provides the perfect teaching tool for glare-less projection in changing light conditions.
The VPL-SW525 WXGA (widescreen) projector with easy installation and multiple media connectivity is an ideal choice for ultra-close projection applications in educational markets.
  • Maximum 2500 lumens brightness with high, standard and low modes
    The VPL-SW525 features three brightness modes for different use - 'High' for naturally white presentations in bright rooms, 'Standard' for everyday use and 'Low' for video in darkened rooms.
  • 3LCD BrightEra technology
    Sony's 0.75 inch BrightEra inorganic TFT 3-LCD panels deliver improved panel light resistance, higher resolution, high brightness and increased panel reliability.
  • WXGA widescreen resolution
    The VPL-SW525 has a color light output of 2500 ANSI lumens and with a native WXGA (1280 x 800) widescreen resolution panel - perfect for video or presentations direct from a laptop or PC.
  • 6000 hours lamp life
    The new driving scheme reduces gap expansion and brightness gradation. A new cooling system allows for uniformity in the temperature of the glass bulb, preventing the glass from clouding.
  • Eco mode key
    Users can easily select power-saving Eco Modes. The most energy-efficient mode is accessible through a single button-push, and further adjustments are available through a user-friendly menu system.
  • ECO lamp dimming
    This projector (if the function is set to on) can reduce power consumption and brightness by 10~15% without user detection during a input image. After a pre-set time, the brightness and power consumption will reduce to 30%.
  • ECO picture mute - (Instant off / Instant On)
    Picture Mute reduces power consumption down to 30% power usage, saving both cost and lamp hours. This feature can be used in the education market as instant off / instant on in-between class changes avoiding the need to power off completely and then turn back on - which increases power consumption and is less time consuming.
  • Digital / HD ready
    HMDI input means the VPL-SW535 can accept High Definition digital signals from PC or Video source.
  • Automatic keystone adjustment
    The projector can detect keystone distortion and correct it automatically. (Note that since this is an electronic correction, it may reduce the picture quality slightly).
  • Smart APA (Auto Pixel Alignment)
    When a computer is used as a picture source, APA automatically optimizes Phase, Pitch and Shift values. These can also be adjusted manually.
  • Auto input search
    Auto Input Search detects which input has an incoming signal, and automatically switches to it. This makes it easier for users to set up the projector prior to making a presentation.
  • Picture muting / audio muting
    If there is a need to blackout the image or turn off the audio from the projector, all it takes is a single button-press on the remote control. One button will mute audio and image at the same time. There is also a separate "mute audio" button for audio-only muting.
  • Six picture modes
    The VPL-SW535 has six available picture modes for correct picture quality; Dynamic, Standard, Game, Living, Cinema, and Presentation. Six picture mode and 3 brightness mode combined, the user can select most suitable picture / brightness mode according to the picture source and environment for perfect image.
  • Audio switcher facility
    To avoid the need for a separate audio switcher, the projector can be used to select between two audio sources, routing them via a variable audio output to the room amplification system.
  • Picture freeze function
    Picture Freeze is useful during presentations, enabling the user to look at other material on their PC's screen without the viewing audience being aware. Freeze the current image, and users can use their PC independently of the display from the projector.
  • Digital zoom
    Digital Zoomallows you to enlarge a selected area of a computer sourced image you are displaying - up to four times.
  • Off and go
    At the end of a presentation, you can turn off the power supply to the projector immediately, avoiding a 'power down' cycle.
  • Direct power On/Off
    With this function, there is no need to go through 'Standby' mode when powering up the projector. The projector can be set to activate as soon as power is applied.
  • Filter cleaning at the same time as lamp replacement
    The filter only needs to be cleaned when a new lamp is fitted, potentially halving disruption due to maintenance.
  • Web control and monitoring / E-mail report
    A built-in Web Browser allows the user or AV manager to check a projector status remotely. Power ON/STANDBY, Input / output, Lamp usage (hours) can be controlled. An E-mail address can also be set to notify lamp exchange/replacement or any unexpected problems.
Sony VPL-SW525 - 3LCD projector - ultra short-throw - white
3LCD projector - 720p
White
Built-in Devices
Speaker
Bundled Services
3 years PrimeSupport
Europe
Ethernet, Fast Ethernet
Brightness
2500 lumens
Contrast Ratio
2500:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Lens
Ultra short-throw lens
Lens Shift Direction
Horizontal, vertical
Bulb type
UHP 210 Watt
Bulb life cycle
Up to 3000 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video (SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, NTSC 3.58)
Digital Video Standard
High-Definition Multimedia Interface (HDMI)
Video Modes
575/50p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 480/60i, 576/50i
Video Output
RGB
Speakers
Speaker(s) - integrated
280 Watt
38.44 cm x 42.34 cm x 12.25 cm
7 kg
3-year warranty
Built-in Devices
Speaker
Bundled Services
Ethernet
Enclosure Colour
White
Europe
Projector
Brightness
2500 lumens
Brightness (Reduced)
1800 lumens
Contrast Ratio
2500:1
Image Size
178 cm - 330 cm
Throw Ratio
0.27 - 0.29:1
Digital Zoom Factor
4x
Resolution
WXGA - WXGA (1280 x 800) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
16:10
Display Format
3,072,000 pixels (1280 x 800) x 3
Max Sync Rate (V x H)
93 Hz x 93 kHz
Bulb type
UHP 210 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction, lens shift dial (horizontal), lens shift dial (vertical)
OSD Languages
Hungarian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese, Korean
Eco-Mode technology, freeze frame, Picture Muting, Smart APA (Auto Pixel Alignment), Auto Input Search, 3LCD Technology, BrightEra, e-mail alerts, Direct Power On, Direct Power Off
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.05x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-5/ +5
Lens Shift Type
Manual
Vertical Lens Shift
4% / 4%
Horizontal Lens Shift
2% / 2%
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
Video Output
Analogue Video Signal
RGB
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
Input Device
External
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x HDMI input - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 1 x S-video input - 4 pin mini-DIN , 1 x RGB output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 (management)
Remote control
Mounting Kit
Included
UL, C-Tick, cUL, NOM, SABS, SASO, CB, CCC, EMC, IC, PSB, FCC, GOST-R, LVD, KC, KUCAS
280 Watt
Power Consumption Operational (Standby)
7.5 Watt
38.44 cm
42.34 cm
12.25 cm
7 kg
Limited warranty - parts and labour - 3 years , Limited warranty - lamp - 1 year / 1000 hours
35 - 85% (non-condensing)
Sound Emission
35 dB
919C C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
