Product
Sony VPL-FX500L XGA LCD 7000 Lumens Projector
Quicklinx: 9RMWWS00 Mfr#: VPL-FX500L
Featuring a very wide range of lens-shift adjustment, and interchangeable lenses, this is a projector that installers can easily fit into awkward places, often reusing mounts and fixtures. The VPL-FX500L is so flexible that it can replace a very wide range of existing equipment.
Outstanding image quality is just one of the many benefits of Sony's 3 LCD-BrightEra technology. By reducing the effects of UV light, it lengthens panel life, brightens the image, and improves color rendition.
Maintenance is kept to an absolute minimum. Automatic lamp-switching means at the end of a lamp's working life, another one, already in place, is brought into use. Synchronized lamp and filter cycles halve the required number of maintenance visits. The VPL-FX500 is the perfect choice for venues that need an extremely bright projector with a high quality image and low maintenance costs
  • BrightEra technology
    Sony's BrightEra Panel technology gives more accurate color rendition, higher brightness and longer lifespan for a lower total cost of ownership.
  • Wide zoom range as standard
    Standard lens has wide zoom capability for more flexibility over positioning of projector, which can installed closer to or further back from the screen.
  • Wide lens shift range
    Wide lens shift range means the projector can be positioned closer to the ceiling, or horizontally offset to avoid ceiling obstacles.
  • Lamp/filter replacement cycles synchronized
    Synchronized lamp and filter replacement effectively halves the number of visits needed to maintain the projector in peak operating condition.
  • Lower power consumption
    Lower operating power consumption helps reduce energy consumption and lowers running costs.
  • Multiple input types
    A wide range of inputs makes it easy to source presentations from almost any type of device including 1080p HD video and up to UXGA digitally from computers.
  • Wide range of image adjustment
    Wide range of image adjustment allows the projector to be installed in a much wider range of locations. Installers are more likely to be able to use existing mounts, or to work around existing obstructions.
Sony VPL-FX500L - 3LCD projector - no lens
3LCD projector
Grey, white
Brightness
7000 lumens
Brightness (Colour)
7000 lumens
Contrast Ratio
2500:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Lens
No lens
Bulb type
High-pressure mercury 330 Watt
Bulb life cycle
Up to 6000 hour(s) - normal mode , Up to 8000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video (SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58)
Video Output
RGB
53 cm x 54.5 cm x 21.3 cm
20 kg
3LCD projector
Enclosure Colour
Grey, white
Projector
Brightness
7000 lumens
Brightness (Colour)
7000 lumens
Brightness (Reduced)
5600 lumens
Contrast Ratio
2500:1
Image Size
102 cm - 1524 cm
Resolution
XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
4:3
Max Sync Rate (V x H)
93 Hz x 93 kHz
Bulb type
Bulb life cycle
OSD Languages
Thai, Chinese (traditional), Chinese (simplified), Vietnamese, English, German, Italian, Norwegian, Portuguese, Polish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese, Korean, Persian
High-bandwidth Digital Content Protection System (HDCP), 3LCD Technology, BrightEra
Lens
No lens
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, composite video, S-Video, DVI
Video Output
Analogue Video Signal
RGB
Input Device
External
1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 1 x S-video input - 4 pin mini-DIN , 2 x RGB input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x component video / RGB input - BNC x 5 , 1 x network - RJ-45 , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C , 1 x remote control , 1 x DVI-D input - 24+1 pin digital DVI
Wireless remote control
Nominal Voltage
53 cm
54.5 cm
21.3 cm
20 kg
35 - 85%
9RMW C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL In Stock £10.46
9RMW C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter In Stock £5.00
9RMW C2G Velocity™ DVI-D™ Female to HDMI® Male Inline Adapter In Stock £7.45
9RMW C2G USB to DVI Adapter Up To 2048 x 1152 In Stock £37.68
9RMW C2G 2m HDMI to DVI-D Digital Video Cable In Stock £8.37
9RMW C2G Pro DVI-D to VGA Converter - Video converter - Black In Stock £50.78
