With an excellent 4,200 ANSI lumens output and XGA resolution, the VPL-FX30 is a versatile choice for a wide range of applications. Able to project detailed, sharp images onto screens up to 600" (diagonal) and with a comprehensive range of adjustments to help installers, this outstanding projector can slot into almost any type of venue.
By massively increasing the LCD panel's resistance to ultraviolet light, BrightEra improves reliability. At the same time, BrightEra shows its superiority over other LCD panels by allowing an increased aperture ratio, which results in a much brighter image, without the drawbacks that can affect other types of high-brightness systems.
The VPL-FX30 is a dependable tool for delivering professional presentations, every day, for years. Fully kitted-out with all the I/O you'll need - including a network connection - it's easy to connect and manage.
It features long lifespan, low cost-of-ownership, and great image quality. The VPL-FX30 is the best reason yet to upgrade to a Sony.
BrightEra technology
Sony's BrightEra panel technology gives more accurate color rendition, higher brightness and longer lifespan for a lower total cost of ownership. -
High brightness
The high brightness is for a clearer image in high ambient light. It is suitable for larger venues. -
Wide zoom range as standard
Standard lens has wide zoom capability for more flexibility over positioning of projector, which can installed closer to or further back from the screen. -
Wide lens shift range
Wide lens shift range means the projector can be positioned closer to the ceiling, or horizontally offset to avoid ceiling obstacles. -
Lamp/filter replacement cycles synchronized
Synchronized lamp and filter replacement effectively halves the number of visits needed to maintain the projector in peak operating condition. -
Lower power consumption
Lower operating power consumption helps reduce energy consumption and lowers running costs. -
Multiple input types
A wide range of inputs makes it easy to source presentations from almost any type of device including 1080p HD video and up to UXGA digitally from computers. -
Monitor output
External monitor output allows presenters to see their slides and videos on a smaller screen in their field of view, so that they never have to turn their back on the audience.
- Sony VPL-FX30 - 3LCD projector - standard lens - grey, white
- 3LCD projector
- Grey, white
- Brightness
- 4200 lumens
- Brightness (Colour)
- 4200 lumens
- Contrast Ratio
- 2000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Lens
- Standard lens
- Lens Shift Direction
- Horizontal, vertical
- Bulb type
- High-pressure mercury 230 Watt
- Bulb life cycle
- Up to 4000 hour(s) - normal mode , Up to 5000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video (SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58)
- Video Output
- RGB
- Power
- AC 120/230 V (50/60 Hz)
- 39 cm x 47.7 cm x 14.8 cm
- 7.9 kg
- 3LCD projector
- Enclosure Colour
- Grey, white
Projector
- Brightness
- 4200 lumens
- 4200 lumens
- Brightness (Reduced)
- 3000 lumens
- Contrast Ratio
- 2000:1
- Image Size
- 102 cm - 1524 cm
- Throw Ratio
- 1.4 - 2.3:1
- Resolution
- XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
- 4:3
- Max Sync Rate (V x H)
- 93 Hz x 93 kHz
- Bulb type
- Bulb life cycle
- OSD Languages
- Thai, Chinese (traditional), Chinese (simplified), Vietnamese, English, German, Italian, Norwegian, Portuguese, Polish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese, Korean, Persian
- High-bandwidth Digital Content Protection System (HDCP), 3LCD Technology, BrightEra
Lens
- Standard lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Zoom Factor
- 1.6x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -30 / +30
- Lens Shift Type
- Manual
- Vertical Lens Shift
- 51% / 0%
- Horizontal Lens Shift
- 33% / 33%
Video Input
- TV System
- SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58
- Analogue video Signal
- Video Interfaces
- VGA, composite video, S-Video, DVI
Video Output
- Analogue Video Signal
- RGB
Input Device
- External
- 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 1 x S-video input - 4 pin mini-DIN , 2 x RGB input - 15 pin HD D-Sub (HD-15) , 3 x audio line-in - mini-phone stereo 3.5 mm , 1 x component video / RGB input - BNC x 5 , 1 x network - RJ-45 , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C , 1 x remote control , 1 x DVI-D input - 24+1 pin digital DVI
- Included Accessories
- Wireless remote control
- Voltage Required
- 39 cm
- 47.7 cm
- 14.8 cm
- 7.9 kg
- 0 °C
- 40 °C
- 35 - 85%
