Sony VPL-FWZ65 6000 ANSI Lumens WXGA 3LCD Technology
Quicklinx: C6DMWS00 Mfr#: VPL-FWZ65
The VPL-FWZ65 laser projector is ideal for a wide range of business, education and general presentation applications. The powerful Z-Phosphor laser light source is teamed with Sony's advanced BrightEra 3LCD projection engine to deliver extremely bright, crisp WXGA resolution images with powerful light output and rich, stable colors.
The laser light source allows thousands of hours of virtually zero maintenance operation without the worry of sudden lamp failures. An automated filter system cuts the hassle of regular dust cleaning. Near-zero maintenance needs are complemented by a range of energy-saving feature, significantly driving down total lifetime ownership costs.
Offering a stylish blend-in design, tidy cable management and low fan noise, the VPL-FWZ65 fits smoothly into almost any environment - from academic institutions, corporate, medical training and public sector organizations to visitor attractions and retail spaces. Seamlessly blend images from multiple projectors to create super-sized displays, or project accurately proportioned images onto angled or curved surfaces. Mount the projector at any angle, even on its side or upside down.
  • Very high image quality
    The Z-Phosphor laser light source is coupled with BrightEra 3LCD projection engine to ensure high image brightness with vivid, natural color reproduction.
  • Advanced picture refinement technologies
    Picture quality is boosted by advanced processing featured on Sony home cinema projectors. Reality Creation uses a powerful pattern-matching database to optimize every pixel. Contrast Enhancer actively analyzes and refines dark and light image areas for sparkling highlights and rich, deep blacks.
  • Crisp WXGA image quality
    View PC presentations or videos with WXGA resolution.
  • Long-lasting operation with virtually no maintenance
    The advanced laser light source offers thousands of hours of operation without lamp exchange, reducing lifetime running costs.
  • Hassle-free automatic filter cleaning
    Focus on great-looking images instead of arduous maintenance tasks: automated filter cleaning system removes dust at equal intervals.
  • Energy saving features
    Reduce running costs even further with convenient energy-saving features: Picture Mute and Auto Dimming.
  • Save time with every presentation
    Quick power on/off dramatically cuts warm-up time after switch-on before you can start presenting at full brightness.
  • 360° free-angle installation capability
    Enjoy greater installation flexibility: position the projector freely at any angle - or its side or even upside down.
  • Powered wide lens shift
    Generous lens shift adjustments give more flexibility for positioning the projector where you need it: close to ceilings or even horizontally offset.
  • Supports HDBaseT
    Simpler, more cost-effective installation and connectivity with digital transmission of HD video, audio and networking/control over a single Ethernet cable.
  • Create super-size displays with edge blending
    Seamlessly join accurately color-matched images from multiple projectors, simplifying creation of stunning super-size displays for corporate and education.
  • Project onto non-flat surfaces with Image Warping
    Easily correct image geometry for natural-looking projections - even on convex or concave surfaces. Corner and edge correction can be easily adjusted with the supplied remote and on-screen menu.
  • Quiet operation
    Low fan noise ensures discreet, unobtrusive operation in quiet environments from museums and galleries to lecture theaters.
  • Attractive blend-in design
    The stylish case design features a flat top surface that blends in discreetly when the projector is ceiling mounted. The clean appearance is accentuated by a terminal cover that reduces cable clutter.
  • Project Side-by-Side
    Project images from two inputs at the same time: ideal for applications such as video conferencing and medical training where two images need to be seen simultaneously.
Sony VPL-FWZ65 - 3LCD projector - standard lens - LAN
3LCD projector - 720p
Brightness (White)
6000 lumens
Brightness (Colour)
6000 lumens
Contrast Ratio
10000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Lens
Standard lens
Lens Shift Direction
Horizontal, vertical
Bulb type
Laser diode
Bulb life cycle
Up to 20000 hour(s)
Video Input
RGB, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58), LAN
Video Modes
1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
453 Watt
46 cm x 51.5 cm x 16.9 cm
16 kg
Ethernet
Projector
Brightness (White)
6000 lumens
Brightness (Colour)
6000 lumens
Brightness (Reduced)
4000 lumens
Contrast Ratio
10000:1
Image Size
102 cm - 1524 cm
Throw Ratio
1.39 - 2.23:1
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Display Format
3,072,000 pixels (1280 x 800) x 3
Max Sync Rate (V x H)
92 Hz x 92 kHz
Bulb type
Laser diode
Bulb life cycle
Up to 20000 hour(s)
Controls & Adjustments
Keystone correction
Picture Muting, Edge blending, High-bandwidth Digital Content Protection System (HDCP), Side-by-Side, 3LCD Technology, BrightEra, Reality Creation, Image Warping
Lens
Standard lens
Focus Type
Powered
Zoom Type
Powered
Zoom Factor
1.6x
Keystone Correction Direction
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Lens Shift Type
Powered
Vertical Lens Shift
5% / 60%
Horizontal Lens Shift
32% / 32%
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video, DVI
Video Modes
LAN and Wireless Image Transferring Protocols
Wired LAN
DVI-D with HDCP Input
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x DVI-D input - 24+1 pin digital DVI , 1 x HDMI input - 19 pin HDMI Type A , 1 x HDBaseT - RJ-45 , 1 x composite video input - BNC , 1 x VGA output - 15 pin D-Sub (DB-15) , 2 x audio line-out - mini-phone stereo 3.5 mm , 1 x DVI-D output - 24+1 pin digital DVI , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45
Remote control
Power Source
AC
453 Watt
Power Consumption Stand by
0.5 Watt
46 cm
51.5 cm
16.9 cm
16 kg
20 - 80% (non-condensing)
Sound Emission
28 dB
C6DM C2G 2m HDMI to DVI-D Digital Video Cable In Stock £11.38
