Sony VPL-FWZ60 5000 ANSI Lumens WXGA 3LCD Technology DVI HDMI
Quicklinx: C6DNWS00 Mfr#: VPL-FWZ60
The VPL-FWZ60 laser projector is ideal for a wide range of business, education and general presentation applications. The powerful Z-Phosphor laser light source is teamed with Sony's advanced BrightEra 3LCD projection engine to deliver extremely bright, crisp WXGA resolution images with generous 5,000 lumens maximum light output and rich, stable colours. Constant Brightness maintains the same brightness throughout the 20,000 hours recommended life span.
The laser light source allows up to 20,000 hours of virtually zero maintenance operation without the worry of sudden lamp failures. An automated filter system cuts the hassle of regular dust cleaning. Near-zero maintenance needs are complemented by a range of energy-saving feature, significantly driving down total lifetime ownership costs.
Offering a stylish blend-in design, tidy cable management and low fan noise, the VPL-FWZ60 fits smoothly into almost any environment - from academic institutions, corporate, medical training and public sector organizations to visitor attractions and retail spaces. Seamlessly blend images from multiple projectors to create super-sized displays, or project accurately proportioned images onto angled or curved surfaces. Mount the projector at any angle, even on its side or upside down. Set-up's easy with a friendly installation menu.
  • Very high image quality with Sony's advanced BrightEra 3LCD projection engine and Z-Phosphor laser light source
    The Z-Phosphor laser light source is coupled with Sony's acclaimed BrightEra 3LCD projection engine to ensure high 5,000 lumen image brightness (in High mode) with vivid, natural color reproduction.
  • Constant Brightness
    Constant Brightness maintains the same brightness throughout the 20,000 hours recommended lifespan.
  • Advanced picture refinement technologies
    Picture quality is boosted by advanced processing featured on Sony home cinema projectors. Reality Creation uses a powerful pattern-matching database to optimize every pixel. Contrast Enhancer actively analyzes and refines dark and light image areas for sparkling highlights and rich, deep blacks.
  • Crisp WXGA image quality
    View PC presentations or videos with WXGA (1280 x 800) 16:10 resolution.
  • Long hours operation with virtually no maintenance
    The advanced laser light source offers up to long hours operation without lamp exchange, reducing lifetime running costs compared with traditional projectors.
  • Hassle-free automatic filter cleaning
    Focus on great-looking images instead of arduous maintenance tasks: automated filter cleaning system removes dust every 100 hours.
  • Energy saving features
    Reduce running costs even further with convenient energy-saving features: Picture Mute and Auto Dimming.
  • Save time with every presentation
    Quick power on/off dramatically cuts warm-up time after switch-on before you can start presenting at full brightness.
  • 360° free-angle installation capability
    Enjoy greater installation flexibility: position the projector freely at any angle - or its side or even upside down.
  • Powered wide lens shift
    Generous lens shift adjustments give more flexibility for positioning the projector where you need it: close to ceilings or even horizontally offset.
  • Included powered standard zoom lens plus wide choice of lens options
    Installation flexibility is increased by a wide range of compatible lens options to suit virtually any size of room and throw requirements. Quick-release bayonet mount simpifies quick lens exchange.
  • Supports HDBaseT
    Simpler, more cost-effective installation and connectivity with digital transmission of HD video, audio and networking/control over a single Ethernet cable.
  • Create super-size displays with Edge Blending
    Seamlessly join accurately color-matched images from multiple projectors, simplifying creation of stunning super-size displays for corporate and education.
  • Project onto non-flat surfaces with Image Warping
    Easily correct image geometry for natural-looking projections - even on convex or concave surfaces. Corner and edge correction can be easily adjusted with the supplied remote and on-screen menu.
  • Quiet operation
    Low fan noise ensures discreet, unobtrusive operation in quiet environments from museums and galleries to lecture theaters.
  • Attractive blend-in design
    The stylish case design features a flat top surface that blends in discreetly when the projector is ceiling mounted. The clean appearance is accentuated by a terminal cover that reduces cable clutter.
  • Picture mode
    Picture mode ensures great-looking pictures in any presentation conditions. Select Standard, Dynamic, Brightness Priority or Multi Screen mode for optimized image quality, with any source and in every room.
  • Simple set-up with friendly Installation menu
    Easily adjust projector settings with remote commander, including image warping and edge blending.
  • Project Side by Side
    Project images from two inputs at the same time: ideal for applications such as video conferencing and medical training where two images need to be seen simultaneously.
Sony VPL-FWZ60 - 3LCD projector - standard lens - LAN
3LCD projector - 720p
Brightness (White)
5000 lumens
Brightness (Colour)
5000 lumens
Contrast Ratio
10000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Lens
Standard lens
Lens Shift Direction
Horizontal, vertical
Bulb type
Laser diode
Bulb life cycle
Up to 20000 hour(s)
Video Input
RGB, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58), LAN
Video Modes
1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
372 Watt
46 cm x 51.5 cm x 16.9 cm
16 kg
Ethernet
Projector
Brightness (White)
5000 lumens
Brightness (Colour)
5000 lumens
Brightness (Reduced)
3500 lumens
Contrast Ratio
10000:1
Image Size
102 cm - 1524 cm
Throw Ratio
1.39 - 2.23:1
Resolution
WXGA - WXGA (1280 x 800) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
16:10
Display Format
3,072,000 pixels (1280 x 800) x 3
Max Sync Rate (V x H)
92 Hz x 92 kHz
Bulb type
Laser diode
Bulb life cycle
Up to 20000 hour(s)
Controls & Adjustments
Keystone correction
Picture Muting, Edge blending, High-bandwidth Digital Content Protection System (HDCP), Side-by-Side, 3LCD Technology, BrightEra, Reality Creation, Image Warping
Lens
Standard lens
Focus Type
Powered
Zoom Type
Powered
Zoom Factor
1.6x
Keystone Correction Direction
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Lens Shift Type
Powered
Vertical Lens Shift
5% / 60%
Horizontal Lens Shift
32% / 32%
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video, DVI
Video Modes
LAN and Wireless Image Transferring Protocols
Wired LAN
DVI-D with HDCP Input
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x DVI-D input - 24+1 pin digital DVI , 1 x HDMI input - 19 pin HDMI Type A , 1 x HDBaseT - RJ-45 , 1 x composite video input - BNC , 1 x VGA output - 15 pin D-Sub (DB-15) , 2 x audio line-out - mini-phone stereo 3.5 mm , 1 x DVI-D output - 24+1 pin digital DVI , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45
Remote control
Power Source
AC
372 Watt
Power Consumption Stand by
0.5 Watt
46 cm
51.5 cm
16.9 cm
16 kg
20 - 80% (non-condensing)
Sound Emission
28 dB
C6DN C2G 2m HDMI to DVI-D Digital Video Cable In Stock £11.38
