Sony VPL-FW65 6300 Lumens WXGA 3LCD Technology DVI HDMI
Quicklinx: C6DRWS00 Mfr#: VPL-FW65
The VPL-FW65 installation projector is ideal for a wide range of business, education and entertainment applications. The energy-efficient High Pressure Mercury (HPM) lamp source is teamed with Sony's advanced BrightEra 3LCD projection engine to deliver extremely bright, crisp WXGA resolution images with powerful 6300 lumens maximum light output and rich, stable colors. Reality creation and contrast enhancer technologies fine-tune image quality even further to assure exceptional clarity and realism with every presentation.
Offering a stylish blend-in design, tidy cable management and low fan noise, the VPL-FW65 fits smoothly into almost any environment - from academic institutions, corporate, medical training and public sector organizations to visitor attractions and retail spaces. Seamlessly blend images from multiple projectors to create super-sized displays, or project accurately proportioned images onto angled or curved surfaces. Mount the projector at any angle, even on its side or upside down. Set-up is easy with a friendly installation menu.
  • Very high image quality with BrightEra 3LCD projection engine
    The energy-efficient High Pressure Mercury (HPM) lamp source is coupled with Sony's acclaimed BrightEra 3LCD projection engine to ensure high 6300 lumen image brightness with vivid, natural color reproduction.
  • Advanced picture refinement technologies
    Picture quality is boosted by advanced processing featured on Sony home cinema projectors. Reality Creation uses a powerful pattern-matching database to optimize every pixel. Contrast Enhancer actively analyzes and refines dark and light image areas for sparkling highlights and rich, deep blacks.
  • Crisp WXGA image quality
    View PC presentations or videos with WXGA (1280 x 800) 16:10 resolution.
  • Hassle-free automatic filter cleaning
    Focus on great-looking images instead of arduous maintenance tasks: automated filter cleaning system removes dust every 100 hours.
  • Energy-saving lamp dimming mode
    Gradually reduces lamp brightness and power consumption without compromising picture quality when the projector isn't being actively used. As soon as it’s needed, full brightness is restored instantly.
  • Powered wide lens shift
    Generous lens shift adjustments give more flexibility for positioning the projector where you need it: close to ceilings or even horizontally offset.
  • Supports HDBaseT
    Simpler, more cost-effective installation and connectivity with digital transmission of HD video, audio and networking/control over a single Ethernet cable.
  • Create super-size displays with edge blending
    Seamlessly join accurately colour-matched images from multiple projectors, simplifying creation of stunning super-size displays for corporate and education.
  • Project onto non-flat surfaces with image warping
    Easily correct image geometry for natural-looking projections – even on convex or concave surfaces. Corner and edge correction can be easily adjusted with the supplied remote and on-screen menu.
  • Quiet operation
    Low fan noise ensures discreet, unobtrusive operation in quiet environments from museums and galleries to lecture theatres.
  • Slim, attractive blend-in design
    The slim, stylish case design features a flat top surface that blends in discreetly when the projector is ceiling mounted. The clean appearance is accentuated by a terminal cover that reduces cable clutter.
  • Picture mode
    Picture mode ensures great-looking presentations in a wide range of operating conditions. Select standard, dynamic, brightness priority or multi screen mode for optimised image quality, with any source and in every room.
  • Simple set-up with friendly installation menu
    Easily adjust projector settings with remote commander, including image warping and edge blending.
  • Project side by side
    Project images from two inputs at the same time: ideal for applications such as video conferencing and medical training where two images need to be seen simultaneously.
Sony VPL-FW65 - 3LCD projector - standard lens - LAN
3LCD projector - 720p
Brightness (White)
6300 lumens
Brightness (Colour)
6300 lumens
Contrast Ratio
2000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Lens
Standard lens
Lens Shift Direction
Horizontal, vertical
Bulb type
Ultra high-pressure mercury 370 Watt
Bulb life cycle
Up to 3000 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
Video Input
RGB, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58), LAN
Video Modes
1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
455 Watt
46 cm x 51.5 cm x 16.9 cm
13 kg
Ethernet
Projector
Brightness (White)
6300 lumens
Brightness (Colour)
6300 lumens
Brightness (Reduced)
4780 lumens
Contrast Ratio
2000:1
Image Size
102 cm - 1524 cm
Throw Ratio
1.39 - 2.23:1
Resolution
WXGA - WXGA (1280 x 800) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
16:10
Display Format
3,072,000 pixels (1280 x 800) x 3
Max Sync Rate (V x H)
92 Hz x 92 kHz
Bulb type
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Hungarian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Japanese, Korean
Edge blending, High-bandwidth Digital Content Protection System (HDCP), Side-by-Side, 3LCD Technology, BrightEra, Reality Creation, Image Warping, Lamp Dimming Function, Contrast Enhancer
Lens
Standard lens
Focus Type
Powered
Zoom Type
Powered
Zoom Factor
1.6x
Keystone Correction Direction
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Lens Shift Type
Powered
Vertical Lens Shift
5% / 60%
Horizontal Lens Shift
32% / 32%
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video, DVI
Video Modes
LAN and Wireless Image Transferring Protocols
Wired LAN
DVI-D with HDCP Input
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x DVI-D input - 24+1 pin digital DVI , 1 x HDMI input - 19 pin HDMI Type A , 1 x HDBaseT - RJ-45 , 1 x composite video input - BNC , 1 x VGA output - 15 pin D-Sub (DB-15) , 2 x audio line-out - mini-phone stereo 3.5 mm , 1 x DVI-D output - 24+1 pin digital DVI , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 (management) , 1 x remote control - mini-phone stereo 3.5 mm (management)
Remote control
Power Source
AC
455 Watt
Power Consumption Stand by
0.5 Watt
46 cm
51.5 cm
16.9 cm
13 kg
20 - 80% (non-condensing)
Sound Emission
28 dB
C6DR C2G 2m HDMI to DVI-D Digital Video Cable In Stock £11.38
