Sony VPL-FH31 WUXGA LCD 4300 Lumens Projector
Quicklinx: 9RMFWS00 Mfr#: VPL-FH31
Brightness: 4300ANSI lumens
Portability: Non-portable
£833.33 ex VAT
£999.99 inc VAT
The VPL-FH31 is designed to fit smoothly into almost any environment where a high-quality projector is required. Its brightness, zoom and throw range, coupled with its wide lens shift range, mean it can perform where other projectors would struggle - even in high ambient light.
Once installed, the VPL-FH31 has excellent image capabilities and a long lifespan that delivers low Total Cost of Ownership. Sony's BrightEra technology improves and maintains color purity throughout the life of the system by protecting the LCD panels against harmful ultra violet light. Clever features such as synchronized lamp and filter replacement cycles reduce costs and downtime.
Featuring the usual wide range of features, the VPL-FH31 also allows for edge blend (multiple projectors with seamless connection), warping and Portrait mode installation for retail, corporate signage applications. Other features include advanced projection capabilities such as side-by-side image projection and DICOM medical training, the VPL-FH31 is an obvious projector choice for venues that demand quality, unique installation locations and practicality.
  • 3 LCD XGA BrightEra panel technology
    Sony's BrightEra Panel Technology gives more accurate color rendition, higher brightness and longer lifespan for a lower Total Cost of Ownership.
  • Ultra high resolution
    The VPL-FH31's WUXGA (1920x1200) 16:10 format resolution delivers absolute best image quality.
  • Very high brightness: 4,300 Lumens Color Light Output
    With very high brightness of 4,300 Lumens Color Light Output, the VPL-FH31 gives a clearer image in high ambient light, making it highly suitable for larger venues.
  • Wide zoom range (x1.6) and throw ratio (1.4 to 2.3) as standard
    The standard lens has a wide zoom capability and throw ratio, offering more flexibility over the positioning of the projector, which can be installed closer to or further away from the screen.
  • Wide lens shift range: vertical: +60%, horizontal: +/- 32%
    The VPL-FH31's wide lens shift range means that the projector can be positioned closer to the ceiling, or horizontally offset to avoid ceiling obstacles.
  • Long lamp replacement time: 3,000-4,000 hours (High/Std)
    Longer lamp life means fewer visits by maintenance personnel and lower Total Cost of Ownership.
  • Lamp/filter replacement cycles synchronized
    Synchronized lamp and filter replacement effectively halves the number of visits needed to maintain the projector in peak operating condition.
  • Interchangeable lenses: Z1024, Z1032
    The VPL-FH31 allows you to choose different lenses for increased flexibility.
  • Edge blend
    Multiple VPL-FH31 projectors have the ability to project a single seamless image onto a screen (wall) creating an exciting visual event, or retail or corporate signage application.
  • Warping projection
    Warping projection allows the customer to adjust the corners and sides of a VPL-FH31 projected image to any convex or concave screen set up or wall for dynamic signage displays.
  • Portrait mode
    The VPL-FH31 can be installed on its side (fan side down) for any portrait signage application.
  • Side by side image projection
    Side by side twin image gives you the ability to project from two inputs (RGB + any other Input) at the same time, making the projector ideal for applications like video conferencing and DICOM medical training.
  • DICOM GSDF Simulation
    The VPL-FH31 offers DICOM GSDF Simulation (HDMI with computer signals), which conforms to GSDF (Grayscale Standard Display Function) of medical standards for DICOM (Digital Imaging and Communication in Medicine).
  • Wide range of image adjustments
    This wide range of image adjustments allows the projector to be installed in almost any location. Where equipment is being upgraded, installers are more likely to be able to use existing mounts. In new installations, they are more likely to be able to work around existing obstructions.
  • User panel alignment
    Pixel alignment shifts the entire image or desired range (H: 16 X V: 10 pixels) for complete color correction.
  • Color matching
    The VPL-FH31 offers brightness and color matching adjustment to the original image for complete image accuracy.
  • Lower operating power consumption than previous models
    Lower operating power consumption helps reduce energy consumption and lowers running costs.
Sony VPL-FH31 - 3LCD projector
3LCD projector
Brightness
4300 lumens
Contrast Ratio
2000:1
Resolution
WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Lens Shift Direction
Horizontal, vertical
Bulb type
UHP 275 Watt
Bulb life cycle
Up to 3000 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video (SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58)
Digital Video Standard
Digital Visual Interface (DVI), High-Definition Multimedia Interface (HDMI)
Video Modes
1080/24p, 1080/60i, 480/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
380 Watt
39 cm x 47.7 cm x 14.8 cm
8 kg
3-year warranty
3LCD projector
Projector
Brightness
4300 lumens
Brightness (Reduced)
3400 lumens
Contrast Ratio
2000:1
Image Size
102 cm - 1524 cm
Throw Ratio
1.4 - 2.3:1
Resolution
WUXGA - WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Display Format
6,912,000 pixels (1920 x 1200) x 3
Max Sync Rate (V x H)
92 Hz x 92 kHz
Bulb type
UHP 275 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction, lens shift dial (horizontal), lens shift dial (vertical)
OSD Languages
Hungarian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese, Korean, Persian
Edge blending, Side-by-Side, 3LCD Technology, BrightEra, DICOM Simulation Mode, Color Matching, Warping Projection
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.6x
Keystone Correction Direction
Vertical
Lens Shift Type
Manual
Vertical Lens Shift
60% / 60%
Horizontal Lens Shift
32% / 32%
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video, DVI
Video Modes
1 x serial RS-232C - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 (management) , 1 x component video / RGB input - BNC x 5 , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x RGB input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x DVI-D input - 24+1 pin digital DVI , 1 x HDMI input - 19 pin HDMI Type A , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - RCA x 2 , 1 x composite video input - RCA , 1 x RGB output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm
2 x AA batteries, remote control
Security Features
Nominal Voltage
380 Watt
Power Consumption Operational (Standby)
10.4 Watt
39 cm
47.7 cm
14.8 cm
8 kg
Limited warranty - 3 years , Limited warranty - lamp - 1 year / 1000 hours
35 - 85% (non-condensing)
Sound Emission
37 dB
30 dB
Brand: Sony
Price Range Ex VAT: 750 - 1000
