Product
Sony VPL-EX315 XGA 4200lm RGB HDMI 3LCD Projector
Quicklinx: C051WS00 Mfr#: VPL-EX315
This projector is ideal for mid-sized or larger classrooms and meeting rooms. Quiet, compact and powerful, it delivers bright, detailed XGA resolution images with significant color light output that can be seen clearly even in bright rooms, with 3LCD technology assuring natural, vivid colors. It is an ideal partner for integrated AV / IT environments, expanding your connectivity options with dual HDMI ports and direct USB display connection. A convenient input labeling makes life simpler, confirming on screen the name of connected devices. Add this projector to a network and see presentations from up to four connected computers simultaneously. Control the projector remotely from smartphones and tablets. You don't even need to bring a PC to meetings - just slip in a USB thumb drive and start presenting. A range of energy-saving features and long-lasting lamp life contribute to low ownership costs. Maintenance is simplified by a rear lamp access feature.
  • Bright, clear images
    With an impressive light output, the projector delivers crisp, bright presentations that can be seen clearly in larger classrooms or meeting rooms. The three brightness modes will suit any environment, from bright daylight to darkened rooms.
  • 3LCD BrightEra technology
    The efficient 3LCD panel system is enhanced by advanced BrightEra technology for impressively bright, consistent, high resolution images with excellent color accuracy and impressive reliability.
  • XGA resolution
    XGA display resolution gives plenty of crisp detail, which makes it ideal for making presentations directly from a laptop, mobile device or DVD player.
  • Powerful audio
    The powerful built-in speaker lets your audiences hear video soundtracks with no need for additional amplification.
  • Energy efficient with long-lasting lamp life
    High-performance lamp technology offers reduced ownership costs plus reduced maintenance, with a long-lasting lamp.
  • Advanced energy-saving
    Advanced lamp technology enables a range of energy-saving features. Auto Light Dimming mode saves energy when the projector is left on without being used. Auto Picture mode automatically adjusts light output to suit the projected scene. Touching a button on the remote mutes the picture temporarily, dramatically reducing power consumption.
  • Quick go
    Don't waste time when you're in a hurry to leave the room: turn off the projector and unplug immediately, with no lengthy waiting for cool-down.
  • Networked presentations
    Project presentations from a networked PC. Present JPEG, PDF and other files wirelessly from a tablet or smartphone.
  • Present wirelessly
    Make presentations wirelessly from a portable or handheld device.
  • USB media viewer
    Slip in a USB drive and display photos, images and graphics with no PC needed.
  • Dual HDMI inputs
    Two HDMI input terminals make it easy to connect HDMI-equipped devices like PCs and media streaming devices.
  • Easier maintenance
    Lamp access has been shifted to the rear of the projector body, making lamp swaps simpler when the projector is hanging from a ceiling mount.
  • Quiet operation
    Low fan noise ensures discreet, unobtrusive operation in classrooms and meeting rooms.
Sony VPL-EX315 - 3LCD projector - LAN
3LCD projector
Built-in Devices
Speaker
Brightness
3800 lumens
Brightness (Colour)
3800 lumens
Contrast Ratio
3300:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb type
Ultra high-pressure mercury 225 Watt
Bulb life cycle
Up to 4000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58), LAN
Video Modes
575/50p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Speakers
Speaker(s) - integrated
304 Watt
36.5 cm x 25.2 cm x 96.2 cm
4 kg
3LCD projector
Built-in Devices
Speaker
Ethernet
Projector
Brightness
3800 lumens
Brightness (Colour)
3800 lumens
Brightness (Reduced)
2500 lumens
Contrast Ratio
3300:1
Image Size
76 cm - 762 cm
Throw Ratio
1.4 - 2.27:1
Resolution
XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
4:3
Display Format
2,359,296 pixels (1024 x 768) x 3
Max Sync Rate (V x H)
92 Hz x 92 kHz
Bulb type
Bulb life cycle
OSD Languages
Hungarian, Czech, Indonesian, Thai, Slovak, Chinese (traditional), Chinese (simplified), Vietnamese, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian, Japanese, Korean
3LCD Technology, BrightEra, USB Viewer, Remote control application support
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.6x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x RGB - 15 pin HD D-Sub (HD-15) , 2 x audio line-in - mini-phone stereo 3.5 mm , 2 x HDMI - 19 pin HDMI Type A , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 , 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B , 1 x microphone input - mini-phone stereo 3.5 mm
Wireless remote control
Nominal Voltage
304 Watt
Power Consumption Stand by
0.5 Watt
36.5 cm
25.2 cm
96.2 cm
4 kg
20 - 80% (non-condensing)
29 dB
C051 C2G 2m USB 2.0 A/B Cable - Black In Stock £3.10
C051 C2G 5m USB 2.0 A/B Cable - Black In Stock £4.51
C051 C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £12.76
C051 C2G 4-Port USB 2.0 Aluminum Hub In Stock £19.32
C051 C2G 12m USB 2.0 A/A Active Extension Cable In Stock £16.73
C051 C2G USB 2.0 To Fast Ethernet Adapter In Stock £21.28
C051 C2G USB Superbooster Extender Kit In Stock £37.81
C051 C2G Trulink® USB to Gigabit Ethernet Adapter In Stock £23.38
C051 C2G USB to HDMI Adapter with Audio Up To 1080p In Stock £42.30
