Sony VPL-EW348 XGA 4200lm RGB HDMI 3LCD Projector
Quicklinx: C04YWS00 Mfr#: VPL-EW348
The VPL-EW348 projector is ideal for mid-sized and larger classrooms and meeting rooms.
Quiet, compact and powerful, it delivers bright, detail-packed WXGA images with 4,200 color light output that can be seen clearly even in bright rooms, with Sony's 3LCD technology assuring natural, vivid colors.
The VPL-EW348 is an ideal partner for today's integrated AV/IT environments, expanding your connectivity options with HDBaseT, dual HDMI ports and Direct USB Display connection. A convenient input label function makes life simpler, confirming on screen the name of connected devices.
Add the VPL-EW348 to a network and see presentations from up to four connected PC/Mac computers simultaneously. Slip in an optional Wi-Fi dongle and present directly wirelessly from laptops, phones or tablets. Control the projector remotely with a free app for smartphones and tablets. You don't even need to bring a PC to meetings - just slip in a USB thumb drive and start presenting.
A range of energy-saving features and long-lasting lamp life contribute to low ownership costs. Maintenance is simplified by a new rear lamp access feature.
  • Bright, clear images with maximum 4,200 lumens color light output
    With a 4,200 lumen maximum light output (in high mode), the VPL-EW348 delivers crisp, bright presentations that can be seen clearly in larger classrooms or meeting rooms. There's a choice of three brightness modes to suit any environment, from bright daylight to darkened rooms.
  • 3LCD BrightEra technology
    The efficient 3LCD panel system is enhanced by advanced BrightEra technology for impressively bright, consistent, high resolution images with excellent color accuracy and impressive reliability.
  • WXGA resolution
    WXGA (1280 x 800) 16:10 display resolution gives plenty of crisp detail: ideal for making presentations direct from a laptop, mobile device or DVD player.
  • Powerful 16W audio
    The powerful built-in 16W speaker (mono) lets your audiences hear video soundtracks with no need for additional amplification.
  • Energy efficient with long-lasting lamp life up to 10,000 hours
    High-performance lamp technology offers reduced ownership costs plus reduced maintenance, with a long-lasting lamp replacement time of approx. 10,000 hours (with brightness in low mode).
  • Advanced energy-saving features
    Advanced lamp technology enables a range of energy-saving features. Auto Light Dimming mode saves energy when the projector is left on without being used. Auto Picture Mode automatically adjusts light output to suit the projected scene. Touching a button on the remote mutes the picture temporarily, dramatically reducing power consumption.
  • Quick go
    Don't waste time when you're in a hurry to leave the room: turn off the projector and unplug immediately, with no lengthy waiting for cool-down.
  • Networked presentations
    Project presentations from a networked PC or Mac. Present JPEG, PDF and other files wirelessly from a tablet or smartphone. Up to four users can project PC/Mac images simultaneously, while up to eight users can connect to one projector. The Projector Station for Network Presentation application for Windows/Mac is included.
  • Control and management from any networked PC
    Projector functions and status can be managed and monitored remotely from any networked PC, using the included Projector Station for Network Control application.
  • USB media viewer
    Slip in a USB drive and display photos, images and graphics with no PC needed.
  • Supports HDBaseT
    Simpler, more cost-effective installation and connectivity with digital transmission of HD video, audio, power and networking/control over a single Ethernet cable.
  • Dual HDMI inputs
    Two HDMI input terminals make it easy to connect HDMI-equipped devices like PCs and media streaming devices.
  • USB Display function for easy one-cable PC connection
    Present pictures and audio from a connected PC or Mac with just one USB cable - you don't even need to install a software driver.
  • Customized input naming labels
    Define your own input labels like 'BD Player', 'PC' and 'Document Camera', making it easier to see on screen what devices are connected and being used.
  • Easier maintenance
    Lamp access has been shifted to the rear of the projector body, making lamp swaps simpler when the projector is hanging from a ceiling mount.
  • Quiet operation
    Low fan noise ensures discreet, unobtrusive operation in classrooms and meeting rooms.
Sony VPL-EW348 - 3LCD projector - 802.11 b/g/n wireless / LAN
3LCD projector - 720p
Built-in Devices
Speaker
Brightness
4200 lumens
Brightness (Colour)
4200 lumens
Contrast Ratio
3700:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Bulb type
Ultra high-pressure mercury 225 Watt
Bulb life cycle
Up to 4000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58), IEEE 802.11 b/g/n wireless / LAN
Video Modes
575/50p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Speakers
Speaker(s) - integrated
329 Watt
36.5 cm x 25.2 cm x 96.2 cm
4.1 kg
Built-in Devices
Speaker
Ethernet
Projector
Brightness
4200 lumens
Brightness (Colour)
4200 lumens
Brightness (Reduced)
2500 lumens
Contrast Ratio
3700:1
Image Size
76 cm - 762 cm
Throw Ratio
1.1 - 1.79:1
Resolution
WXGA - WXGA (1280 x 800) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
16:10
Display Format
3,072,000 pixels (1280 x 800) x 3
Max Sync Rate (V x H)
92 Hz x 92 kHz
Bulb type
Bulb life cycle
OSD Languages
Hungarian, Czech, Indonesian, Thai, Slovak, Chinese (traditional), Chinese (simplified), Vietnamese, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian, Japanese, Korean
3LCD Technology, BrightEra, USB Viewer, Remote control application support
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.6x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-20 / +20
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
LAN and Wireless Image Transferring Protocols
Wired LAN, Wi-Fi
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x RGB - 15 pin HD D-Sub (HD-15) , 2 x audio line-in - mini-phone stereo 3.5 mm , 2 x HDMI - 19 pin HDMI Type A , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 , 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B , 1 x microphone input - mini-phone stereo 3.5 mm
Wireless remote control, wireless LAN unit
329 Watt
Power Consumption Stand by
0.5 Watt
36.5 cm
25.2 cm
96.2 cm
4.1 kg
20 - 80% (non-condensing)
29 dB
C04Y C2G 5m USB 2.0 A/B Cable - Black In Stock £5.09
