Your basket is empty
Sony VPL-EW255 WXGA LCD 3200 Lumens Projector
Quicklinx: 9RL4WS00 Mfr#: VPL-EW255
Combining superb widescreen WXGA image quality with smart energy-efficient features, the VPL-EW255 portable projector enhances learning with powerful presentations that really stand out. Simple to use and wireless ready, the projector is ideal for maximizing student engagement in the networked classrooms, making it your ideal partner throughout the busy school day.
Sony BrightEra panel technology assures clearpictures in any conditions, from daylight to darkened classrooms. Plenty of interfaces allow easy connection, while a choice of Picture Modes optimizes viewing with any source - slide presentations, PC documents, pictures or videos. Adding an optional Wi-Fi module lets students and teachers wirelessly share homework, images and graphics from mobile devices like smartphones and tablets.
Sony VPL-EW255 - 3LCD projector
3LCD projector - High Definition 720p
Built-in Devices
Speaker
Brightness
3200 lumens
Brightness (Colour)
3200 lumens
Contrast Ratio
2700:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Bulb type
Ultra high-pressure mercury 210 Watt
Bulb life cycle
Up to 4000 hour(s) / up to 10000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, NTSC 3.58)
Video Modes
1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Speakers
Speaker(s) - integrated
301 Watt
36.5 cm x 25.2 cm x 9.62 cm
3.9 kg
3LCD projector - HD 720p
Built-in Devices
Speaker
Ethernet
Projector
Brightness
3200 lumens
Brightness (Colour)
3200 lumens
Brightness (Reduced)
1500 lumens
Contrast Ratio
2700:1
Image Size
0.76 m - 7.62 m
Throw Ratio
1.4 - 2.27:1
Resolution
WXGA - WXGA (1280 x 800) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
16:10
Display Format
3,072,000 pixels (1280 x 800) x 3
Max Sync Rate (V x H)
93 Hz x 93 kHz
Bulb type
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Hungarian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Japanese, Korean
High-bandwidth Digital Content Protection System (HDCP), 3LCD Technology, BrightEra
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.6x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-20 / +20
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x HDMI - 19 pin HDMI Type A , 1 x S-video input - 4 pin mini-DIN , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 (management) , 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x composite video output - RCA , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm
Nominal Voltage
301 Watt
Power Consumption Stand by
5.1 Watt
36.5 cm
25.2 cm
9.62 cm
3.9 kg
35 - 85% (non-condensing)
9RL4 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
9RL4 C2G 0.5m Select High Speed HDMI with Ethernet In Stock £5.76
9RL4 C2G 5m Select High Speed HDMI with Ethernet In Stock £15.70
9RL4 C2G 10m Select High Speed HDMI with Ethernet In Stock £30.15
9RL4 C2G 15m Select High Speed HDMI with Ethernet In Stock £40.84
9RL4 C2G Pro HDMI to VGA Converter In Stock £46.35
