Combining superb widescreen WXGA image quality with smart energy-efficient features, the VPL-EW235 portable projector enhances learning with powerful presentations that really stand out. Simple to use and wireless ready, the projector is ideal for maximizing student engagement in today's networked classrooms, making it your ideal partner throughout the busy school day.
Sony BrightEra panel technology assures clear pictures in any conditions, from daylight to darkened classrooms. Plenty of interfaces allow easy connection, while a choice of Picture Modes optimizes viewing with any source - slide presentations, PC documents, pictures or videos. Adding an optional Wi-Fi module lets students and teachers wirelessly share homework, images and graphics from mobile devices like smartphones and tablets. There's a wide range of smart energy-saving features built in. And with a recommended lamp replacement time many hours, downtime and maintenance costs are minimized.
Energy efficient with long-lasting lamp
The lamp driver optimally controls the wattage of the lamp and achieves a long-lasting lamp time. The recommended lamp replacement time is extended significantly. -
Advanced energy-saving features
Advanced lamp technology enables robust energy-saving features. For example, greater brightness control in Auto Light Dimming mode saves considerable energy when the projector is left on without being used. During projection, Auto Lamp Mode automatically adjusts light output to suit the projected scene. When you need to mute the picture temporarily, light output can be completely deactivated to minimize energy consumption. -
High image quality 3LCD BrightEra natural and vivid color images
Widescreen WXGA (1280 x 800) 16:10 screen resolution, 3LCD BrightEra natural and vivid color images, plus various Picture Modes for optimizing image quality, make the projector one of the best in its class. Thanks to the optical system projecting three basic colors constantly, the projector offers excellent light efficiency, ensuring colorful and bright images. Sony's BrightEra panels deliver improved panel light resistance, higher resolution, high brightness and increased panel reliability. High color reproducibility is important especially when using colorful content, such as materials used in classrooms. -
Various picture modes for optimal picture quality
The projector has six available picture modes for correct picture quality: Dynamic, Standard, Presentation, Blackboard, Game, and Cinema. With six picture modes and three brightness modes combined, the user can select the most suitable picture/brightness combination according to the picture source and environment, to create the optimal image. -
USB display
The projector allows you to display pictures and audio with one USB cable. You do not need to install any driver for this function. It is a convenient way to connect to the projector when you want to connect easily. -
Input label
The input label, which appears in the input menu on screen, can be customised. This gives users a clear understanding of which equipment is connected. -
Built-in speaker
The projector includes a 16W monaural speaker.
- Sony VPL-EW235 - 3LCD projector - LAN
- 3LCD projector - 720p
- Built-in Devices
- Speaker
- Brightness
- 2700 lumens
- Brightness (Colour)
- 2700 lumens
- Contrast Ratio
- 2700:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Bulb type
- UHP 210 Watt
- Bulb life cycle
- Up to 4000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video (SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, NTSC 3.58), LAN
- Video Modes
- 575/50p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 278 Watt
- 36.5 cm x 25.2 cm x 9.62 cm
- 3.9 kg
- Built-in Devices
- Speaker
- Networking
- Ethernet
Projector
- Brightness
- 2700 lumens
- 2700 lumens
- Brightness (Reduced)
- 1500 lumens
- Contrast Ratio
- 2700:1
- Image Size
- 76 cm - 762 cm
- Throw Ratio
- 1.37 - 1.80:1
- Resolution
- WXGA - WXGA (1280 x 800) (native) / 1600 x 1200 (resized)
- 16:10
- Display Format
- 3,072,000 pixels (1280 x 800) x 3
- Max Sync Rate (V x H)
- 93 Hz x 93 kHz
- Bulb type
- UHP 210 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Hungarian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Japanese, Korean
- Blackboard Mode, High-bandwidth Digital Content Protection System (HDCP), 3LCD Technology, BrightEra, 16:10 aspect ratio support, Game mode, Dynamic Mode, Power Save Mode
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Zoom Factor
- 1.3x
- Keystone Correction Direction
- Horizontal
- Vertical Keystone Correction
- -20 / +20
Video Input
- TV System
- SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, NTSC 3.58
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, component video, composite video, S-Video
- Video Modes
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
- Speakers
- 1 x mixed channel
- 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 (management) , 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B , 1 x microphone input - mini-phone 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - RCA x 2
- Included Accessories
- Wireless remote control
- Power Source
- AC
- Voltage Required
- 278 Watt
- Power Consumption Stand by
- 5.1 Watt
- 36.5 cm
- 25.2 cm
- 9.62 cm
- 3.9 kg
- 0 °C
- 40 °C
- 35 - 85% (non-condensing)
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
