The VPL-DX147 is packed with features optimized for the business and education markets at a reasonable price. The projector is compact and lightweight, with its simple design making it very easy to set up.
Sony 3LCD BrightEra panel technology provides bright and colorful projection. Plenty of interfaces allow easy connection, while a choice of Picture Modes optimizes viewing with any source – slide presentations, PC documents, pictures or videos. There’s a range of smart energy-saving features built in, including auto power saving function. And with a recommended lamp replacement time of 10,000 hours, downtime and maintenance costs are minimized.
Compact, lightweight and stylish design
The VPL-DX147 has a compact and lightweight body with a small footprint and a light weight. This compact, lightweight projector is convenient for carrying around a meeting room or classroom. -
Energy efficient with long-lasting lamp of 10,000 hours
The lamp driver optimally controls the wattage of the lamp and achieves a long-lasting lamp time of 10,000 hours. The recommended lamp replacement time is extended by 43%, compared to the previous model. -
Advanced energy-saving features
Advanced lamp technology enables robust energy-saving features. For example, greater brightness control in Auto Light Dimming mode saves considerable energy when the projector is left on without being used. During projection, Auto Lamp Mode automatically adjusts light output to suit the projected scene. When you need to mute the picture temporarily, light output can be completely deactivated to minimize energy consumption. -
High image quality 3LCD BrightEra natural and vivid color images
Widescreen XGA (1280 x 800) 4:3 screen resolution, 3LCD BrightEra natural and vivid color images, plus various Picture Modes for optimizing image quality, make the projector one of the best in its class. Thanks to the optical system projecting three basic colors constantly, the projector offers excellent light efficiency, ensuring colorful and bright images. Sony's BrightEra panels deliver improved panel light resistance, higher resolution, high brightness and increased panel reliability. High color reproducibility is important especially when using colorful content, such as materials used in classrooms. -
Various picture modes for optimal picture quality
The projector has six available picture modes for correct picture quality: Dynamic, Standard, Presentation, Blackboard, Game, and Cinema. With six picture modes and three brightness modes combined, the user can select the most suitable picture/brightness combination according to the picture source and environment, to create the optimal image. -
Network presentation (LAN)
When the projector is installed in a LAN, presentations can be projected from any PC and Mac on the network. A tablet or smartphone can be connected at the same time. You can project jpg, pdf and other supported formats. Up to four users can project PC/Mac images simultaneously, while up to eight users can connect to one projector. -
USB display
The projector allows you to display pictures and audio with one USB cable. You do not need to install any driver for this function. It is a convenient way to connect to the projector when you want to connect easily. -
Input name customization
It is possible to customize the input names that appear in the input menu on screen. It allows users to understand clearly what equipment is connected.
- Sony VPL-DX147 - 3LCD projector - portable - LAN
- 3LCD projector
- Built-in Devices
- Speaker
- Brightness
- 3200 lumens
- Contrast Ratio
- 3000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Bulb type
- Ultra high-pressure mercury 210 Watt
- Bulb life cycle
- Up to 3000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, composite video, component video (SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, NTSC 3.58), LAN
- Video Modes
- 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 286 Watt
- 31.5 cm x 23.05 cm x 7.5 cm
- 2.6 kg
- 3LCD projector
- Built-in Devices
- Speaker
- Networking
- Ethernet
Projector
- Brightness
- 3200 lumens
- Brightness (Reduced)
- 1900 lumens
- Contrast Ratio
- 3000:1
- Image Size
- 76 cm - 762 cm
- Throw Ratio
- 1.37 - 1.8:1
- Resolution
- XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
- 4:3
- Display Format
- 2,359,296 pixels (1024 x 768) x 3
- Max Sync Rate (V x H)
- 92 Hz x 92 kHz
- Bulb type
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Hungarian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Japanese, Korean
- Blackboard Mode, High-bandwidth Digital Content Protection System (HDCP), 3LCD Technology, BrightEra, Auto Dimming Mode
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Zoom Factor
- 1.3x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -30 / +30
Video Input
- TV System
- SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, NTSC 3.58
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video
- Video Modes
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 1 Watt
- Speakers
- 1 x mixed channel
- 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x HDMI - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x network - RJ-45 , 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B
- Included Accessories
- Carrying case, lens cover, wireless remote control, wireless LAN unit, lithium coin cell battery
- Cables Included
- 1 x VGA cable
- Power Source
- AC
- Voltage Required
- 286 Watt
- Power Consumption Stand by
- 0.5 Watt
- Software Included
- Projector Station
- 31.5 cm
- 23.05 cm
- 7.5 cm
- 2.6 kg
- 0 °C
- 35 °C
- 20 - 80% (non-condensing)
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
