Sony VPL-DX142 XGA 3200 Lumens Projector
Quicklinx: 9V12WS00 Mfr#: VPL-DX142
The VPL-DX142 is packed with features optimized for the business and education markets at a reasonable price. The projector is compact and lightweight, with its simple design making it very easy to set up.
Sony 3LCD BrightEra panel technology provides bright and colorful projection. Plenty of interfaces allow easy connection, while a choice of Picture modes optimizes viewing with any source - slide presentations, PC documents, pictures or videos. There's a range of smart energy-saving features built in, including auto power saving function. And with a recommended lamp replacement time, downtime and maintenance costs are minimized.
  • Compact, lightweight and stylish design
    The VPL-DX142 has a compact and lightweight body with a small footprint and a light weight. This compact, lightweight projector is convenient for carrying around a meeting room or classroom.
  • Energy efficient with long-lasting lamp
    The lamp driver optimally controls the wattage of the lamp and achieves a long-lasting lamp. The recommended lamp replacement time is extended by 43%, compared to the previous model.
  • Advanced energy-saving features
    Advanced lamp technology enables robust energy-saving features. For example, greater brightness control in Auto light dimming mode saves considerable energy when the projector is left on without being used. During projection, Auto lamp mode automatically adjusts light output to suit the projected scene. When you need to mute the picture temporarily, light output can be completely deactivated to minimize energy consumption.
  • High image quality 3LCD BrightEra natural and vivid color images
    Widescreen XGA (1280 x 800) 4:3 screen resolution, 3LCD BrightEra natural and vivid color images, plus various Picture Modes for optimizing image quality, make the projector one of the best in its class. Thanks to the optical system projecting three basic colors constantly, the projector offers excellent light efficiency, ensuring colorful and bright images. Sony's BrightEra panels deliver improved panel light resistance, higher resolution, high brightness and increased panel reliability. High color reproducibility is important especially when using colorful content, such as materials used in classrooms.
  • Various picture modes for optimal picture quality
    The projector has six available picture modes for correct picture quality: Dynamic, Standard, Presentation, Blackboard, Game, and Cinema. With six picture modes and three brightness modes combined, the user can select the most suitable picture/brightness combination according to the picture source and environment, to create the optimal image.
Sony VPL-DX142 - 3LCD projector - portable
3LCD projector
Built-in Devices
Speaker
Brightness
3200 lumens
Contrast Ratio
3000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb type
Ultra high-pressure mercury 210 Watt
Bulb life cycle
Up to 3000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, component video (SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, NTSC 3.58)
Video Modes
1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Speakers
Speaker(s) - integrated
277 Watt
31.5 cm x 23.05 cm x 7.5 cm
2.5 kg
3LCD projector
Built-in Devices
Speaker
Projector
Brightness
3200 lumens
Brightness (Reduced)
2000 lumens
Contrast Ratio
3000:1
Image Size
76.2 cm - 762 cm
Throw Ratio
1.37 - 1.8:1
Resolution
XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
4:3
Display Format
2,359,296 pixels (1024 x 768) x 3
Max Sync Rate (V x H)
92 Hz x 92 kHz
Bulb type
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Hungarian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese, Korean
Blackboard Mode, High-bandwidth Digital Content Protection System (HDCP), 3LCD Technology, BrightEra, Auto Dimming Mode
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.3x
Keystone Correction Direction
Horizontal
Vertical Keystone Correction
-30 / +30
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
1 Watt
Speakers
1 x mixed channel
1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x HDMI - 19 pin HDMI Type A
Wireless remote control
Power Source
AC
277 Watt
Power Consumption Stand by
0.5 Watt
31.5 cm
23.05 cm
7.5 cm
2.5 kg
35 °C
20 - 80% (non-condensing)
9V12 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
