Your basket is empty
Sony VPL-DX142 XGA 3200 Lumens Projector
Quicklinx: 9V12WS00 Mfr#: VPL-DX142
The VPL-DX142 is packed with features optimized for the business and education markets at a reasonable price. The projector is compact and lightweight, with its simple design making it very easy to set up.
Sony 3LCD BrightEra panel technology provides bright and colorful projection. Plenty of interfaces allow easy connection, while a choice of Picture modes optimizes viewing with any source - slide presentations, PC documents, pictures or videos. There's a range of smart energy-saving features built in, including auto power saving function. And with a recommended lamp replacement time, downtime and maintenance costs are minimized.
Sony VPL-DX142 - 3LCD projector - portable
3LCD projector
Built-in Devices
Speaker
Brightness
3200 lumens
Contrast Ratio
3000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb type
Ultra high-pressure mercury 210 Watt
Bulb life cycle
Up to 3000 hour(s) / up to 10000 hour(s) (economic mode)
Video Input
RGB, component video (SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, NTSC 3.58)
Video Modes
1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Speakers
Speaker(s) - integrated
277 Watt
31.5 cm x 23.05 cm x 7.5 cm
2.5 kg
3LCD projector
Built-in Devices
Speaker
Projector
Brightness
3200 lumens
Brightness (Reduced)
2000 lumens
Contrast Ratio
3000:1
Image Size
76.2 cm - 762 cm
Throw Ratio
1.37 - 1.8:1
Resolution
XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
4:3
Display Format
2,359,296 pixels (1024 x 768) x 3
Max Sync Rate (V x H)
92 Hz x 92 kHz
Bulb type
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Hungarian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese, Korean
Blackboard Mode, High-bandwidth Digital Content Protection System (HDCP), 3LCD Technology, BrightEra, Auto Dimming Mode
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.3x
Keystone Correction Direction
Horizontal
Vertical Keystone Correction
-30 / +30
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
1 Watt
Speakers
1 x mixed channel
1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x HDMI - 19 pin HDMI Type A
Wireless remote control
Power Source
AC
Nominal Voltage
277 Watt
Power Consumption Stand by
0.5 Watt
31.5 cm
23.05 cm
7.5 cm
2.5 kg
35 °C
20 - 80% (non-condensing)
9V12 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
9V12 C2G 0.5m Select High Speed HDMI with Ethernet In Stock £5.76
9V12 C2G 5m Select High Speed HDMI with Ethernet In Stock £15.70
9V12 C2G 10m Select High Speed HDMI with Ethernet In Stock £30.15
9V12 C2G 15m Select High Speed HDMI with Ethernet In Stock £40.84
9V12 C2G Pro HDMI to VGA Converter In Stock £46.35
