The VPL-CH375 delivers an outstanding brightness of 5000 lumens and ultra high-quality images with WUXGA resolution. Sony 3LCD BrightEra panel technology provides higher picture quality, substantially brighter images, higher efficiency, consistent color stability and longer durability. It also delivers installation flexibility, environment-friendly features, and a low total cost of ownership, in a stylish design that blends into any decor. The lens shift/zoom capability and the image correction features easily allow users to fit any image onto the screen, even from an offset projection angle.
The projector allows simple connectivity using an HDBaseT digital interface, multi signal transmission system, providing a single cable, cost-effective, long-distance, and high-quality digital transmission solution. Additionally, the projector is economically designed for optimum energy efficiency, thanks to its energy saving features and has all the features and functionality that you would expect from Sony, particularly in terms of installation, projection, usability and maintenance.
High resolution WUXGA image
The VPL-CH375 delivers an amazing resolution of WUXGA (1920 x 1200). Extremely clear and detailed high-quality images are projected, even on a large screen. The VPL-CH375 is the ultimate tool for projecting images in a range of applications requiring exceptional detail. -
High image quality 3LCD BrightEra natural and vivid color images with high brightness
Thanks to the optical system projecting three basic colors constantly, the projector offers excellent light efficiency, which ensures colorful and bright images. Sony's BrightEra panels deliver improved panel light resistance, higher resolution, high brightness and increased panel reliability. High color reproducibility is important especially when using colorful content, such as materials used in classrooms. -
Fine lens shift
The VPL-CH375's lens shift range adjustment means that the projector can be positioned picture-perfect and horizontally offset to avoid any minor ceiling obstacles. -
Connectivity via HDBaseT
The projector allows simple connectivity using an HDBaseT digital interface, multi signal transmission system, providing a single cable, cost-effective, long-distance, and high-quality digital transmission solution. -
Blend-in design
The VPL-CH375 has a low-profile chassis, so it appears to blend into the ceiling or wall on which it is mounted. -
Advanced energy-saving features
Advanced lamp technology enables robust energy-saving features. For example, greater brightness control in Auto Light Dimming mode saves considerable energy when the projector is left on without being used. During projection, Auto Picture Mode automatically adjusts light output to suit the projected scene. When you need to mute the picture temporarily, light output can be completely deactivated to minimize energy consumption.
- Sony VPL-CH375 - 3LCD projector
- 3LCD projector - 1080p
- Built-in Devices
- Speaker
- Brightness
- 5000 lumens
- Contrast Ratio
- 2500:1
- Resolution
- WUXGA (1920 x 1200)
- Native Aspect Ratio
- 16:10
- Lens Shift Direction
- Horizontal, vertical
- Bulb type
- Ultra high-pressure mercury 280 Watt
- Bulb life cycle
- Up to 2500 hour(s) - normal mode , Up to 3500 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video (SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, NTSC 3.58)
- Video Modes
- 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
- Speakers
- Speaker(s) - integrated
- Power
- AC 100/230 V (50/60 Hz)
- 367 Watt
- 40.6 cm x 33.05 cm x 11.3 cm
- 5.7 kg
- Built-in Devices
- Speaker
- Networking
- Ethernet
Projector
- Brightness
- 5000 lumens
- Brightness (Reduced)
- 3100 lumens
- Contrast Ratio
- 2500:1
- Image Size
- 102 cm - 762 cm
- Throw Ratio
- 1.5 - 2.2:1
- Resolution
- WUXGA - WUXGA (1920 x 1200)
- 16:10
- Display Format
- 6,912,000 pixels (1920 x 1200) x 3
- Max Sync Rate (V x H)
- 92 Hz x 92 kHz
- Bulb type
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- Eco-Mode technology, 3LCD Technology, BrightEra, Vivid Color Control
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Zoom Factor
- 1.45x
- Keystone Correction Direction
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -20 / +20
- Lens Shift Type
- Manual
- Vertical Lens Shift
- 5% / 5%
- Horizontal Lens Shift
- 4% / 4%
Video Input
- TV System
- SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, NTSC 3.58
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 12 Watt
- Speakers
- 1 x mixed channel
- 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x HDMI - 19 pin HDMI Type A , 1 x S-video input - 4 pin mini-DIN , 1 x HDBaseT , 1 x composite video input - RCA , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x remote control - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B , 1 x microphone input - mini-phone stereo 3.5 mm
- Included Accessories
- Lens cover, remote control
- Power Source
- AC
- Voltage Required
- 367 Watt
- Power Consumption Stand by
- 0.5 Watt
- 40.6 cm
- 33.05 cm
- 11.3 cm
- 5.7 kg
- 0 °C
- 40 °C
- 20 - 80% (non-condensing)
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
