Sony VPL-CH375 WUXGA 3LCD 5000 Lumens Projector
Quicklinx: BGMZWS00 Mfr#: VPL-CH375
Brightness: 5000ANSI lumens
Portability: Non-portable
£1,087.78 ex VAT
£1,305.33 inc VAT
The VPL-CH375 delivers an outstanding brightness of 5000 lumens and ultra high-quality images with WUXGA resolution. Sony 3LCD BrightEra panel technology provides higher picture quality, substantially brighter images, higher efficiency, consistent color stability and longer durability. It also delivers installation flexibility, environment-friendly features, and a low total cost of ownership, in a stylish design that blends into any decor. The lens shift/zoom capability and the image correction features easily allow users to fit any image onto the screen, even from an offset projection angle.
The projector allows simple connectivity using an HDBaseT digital interface, multi signal transmission system, providing a single cable, cost-effective, long-distance, and high-quality digital transmission solution. Additionally, the projector is economically designed for optimum energy efficiency, thanks to its energy saving features and has all the features and functionality that you would expect from Sony, particularly in terms of installation, projection, usability and maintenance.
  • High resolution WUXGA image
    The VPL-CH375 delivers an amazing resolution of WUXGA (1920 x 1200). Extremely clear and detailed high-quality images are projected, even on a large screen. The VPL-CH375 is the ultimate tool for projecting images in a range of applications requiring exceptional detail.
  • High image quality 3LCD BrightEra natural and vivid color images with high brightness
    Thanks to the optical system projecting three basic colors constantly, the projector offers excellent light efficiency, which ensures colorful and bright images. Sony's BrightEra panels deliver improved panel light resistance, higher resolution, high brightness and increased panel reliability. High color reproducibility is important especially when using colorful content, such as materials used in classrooms.
  • Fine lens shift
    The VPL-CH375's lens shift range adjustment means that the projector can be positioned picture-perfect and horizontally offset to avoid any minor ceiling obstacles.
  • Connectivity via HDBaseT
  • Blend-in design
    The VPL-CH375 has a low-profile chassis, so it appears to blend into the ceiling or wall on which it is mounted.
  • Advanced energy-saving features
    Advanced lamp technology enables robust energy-saving features. For example, greater brightness control in Auto Light Dimming mode saves considerable energy when the projector is left on without being used. During projection, Auto Picture Mode automatically adjusts light output to suit the projected scene. When you need to mute the picture temporarily, light output can be completely deactivated to minimize energy consumption.
Sony VPL-CH375 - 3LCD projector
3LCD projector - 1080p
Built-in Devices
Speaker
Brightness
5000 lumens
Contrast Ratio
2500:1
Resolution
WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Lens Shift Direction
Horizontal, vertical
Bulb type
Ultra high-pressure mercury 280 Watt
Bulb life cycle
Up to 2500 hour(s) - normal mode , Up to 3500 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video (SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, NTSC 3.58)
Video Modes
1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Speakers
Speaker(s) - integrated
AC 100/230 V (50/60 Hz)
367 Watt
40.6 cm x 33.05 cm x 11.3 cm
5.7 kg
Built-in Devices
Speaker
Ethernet
Projector
Brightness
5000 lumens
Brightness (Reduced)
3100 lumens
Contrast Ratio
2500:1
Image Size
102 cm - 762 cm
Throw Ratio
1.5 - 2.2:1
Resolution
WUXGA - WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Display Format
6,912,000 pixels (1920 x 1200) x 3
Max Sync Rate (V x H)
92 Hz x 92 kHz
Bulb type
Bulb life cycle
Controls & Adjustments
Keystone correction
Eco-Mode technology, 3LCD Technology, BrightEra, Vivid Color Control
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.45x
Keystone Correction Direction
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-20 / +20
Lens Shift Type
Manual
Vertical Lens Shift
5% / 5%
Horizontal Lens Shift
4% / 4%
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
12 Watt
Speakers
1 x mixed channel
1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x HDMI - 19 pin HDMI Type A , 1 x S-video input - 4 pin mini-DIN , 1 x HDBaseT , 1 x composite video input - RCA , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x remote control - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B , 1 x microphone input - mini-phone stereo 3.5 mm
Lens cover, remote control
Power Source
AC
Nominal Voltage
367 Watt
Power Consumption Stand by
0.5 Watt
40.6 cm
33.05 cm
11.3 cm
5.7 kg
20 - 80% (non-condensing)
BGMZ C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BGMZ C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.34
BGMZ C2G 5m Select High Speed HDMI with Ethernet In Stock £21.17
BGMZ C2G 10m Select High Speed HDMI with Ethernet In Stock £40.63
BGMZ C2G 15m Select High Speed HDMI with Ethernet In Stock £55.03
BGMZ C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
Brand: Sony
Price Range Ex VAT: 1000 - 1500
