The SmartBand Talk SWR30 from Sony is a fashion SmartBand with a curved display and call function. Let SmartBand Talk SWR30 tell you how you live and move. It detects when you have been running, walking and even when you have been sleeping. Let the SmartBand Talk SWR30 tell you how you live and move.
True handsfree calling
You have everything you need to make and take calls on your wrist. When a call comes in, press once to answer and greet your caller without taking your smartphone from your pocket or bag. You never miss a call. -
Keep yourself updated
In the SmartBand Talk display you can see and open message and other notifications when they come in. Keep in touch and see what comes in. -
Moving is living
SmartBand Talk keeps track of how you live and move. It detects when you run, walk and even when you sleep. View daily activities in the SmartBand Talk E Ink display or use the Lifelog app for in-depth analysis of your progress. Learn how you live, and then live better. -
Calling on your wrist
The SmartBand Talk SWR30 has a microphone and loudspeaker built in for a natural calling style. When a call comes in, the SmartBand Talk SWR30 vibrates. You won't miss a call. You can also use the SmartBand Talk SWR30 to initiate a call. -
Voice interaction
Make a voice memo for yourself while on the move. The SmartBand Talk SWR30 also supports voice commands for handsfree convenience in six languages.
- Sony SmartBand Talk SWR30 activity tracker - 2 MB - white
- Product Type
- Activity tracker
- Tracking Data
- Time, sleep activity, steps taken, elevation
- Connectivity
- NFC, Bluetooth
- Display
- Two-colour (monochrome) E Ink - 1.4" - 296 x 128 pixels - 192 ppi
- Processor
- ARM Cortex-M4
- Storage
- 2 MB
- Notifications
- Calendar
- Social Networks
- Micro-USB (charging only), answering a call
- Supported Host Device OS
- Android 4.4 (KitKat) or later
- Battery
- Lithium polymer - 70 mAh
- Battery Run Time
- Up to 72 hours
- White
- 23.5 mm x 9.5 mm
- 24 g
- Designed For
- XPERIA C5 Ultra, C5 Ultra Dual, M4 Aqua, M4 Aqua Dual
- Product Type
- Activity tracker
- Supported Social Networks and Blogs
- Notifications
- Calendar
- Tracking Data
- Audio Input
- Microphone
- Audio Output
- Speaker
- White
- Sensors
- Accelerometer, altimeter
Storage
- Capacity
- 2 MB
Display
- E Ink - two-colour (monochrome)
- Resolution
- 296 x 128 pixels
- Diagonal Size
- 1.4"
- Pixel Density
- 192 ppi
- Wireless Interface
- NFC, Bluetooth 4.0
- Bluetooth Profiles
- Hands-Free Profile (HFP), Radio Frequency Communication (RFCOMM)
CPU
- Manufacturer
- ARM
- Cortex-M4
RAM
- Size
- 256 KB
- Technology
- Lithium polymer
- Capacity
- 70 mAh
- Run Time (Up To)
- 72 hours
- Run Time Details
- Talk time - up to 1 hour(s)
- Details
- Main unit: 22.3 mm x 9.5 mm x 47.5 mm 12 g
- Preloaded Software
- Voice Commands
- Vibrating Alert
- Protection
- Dustproof, waterproof
- IP68
- Included Accessories
- 2 wrist straps
- -5 °C
- 50 °C
- 5 - 95%
- Designed For
- Sony XPERIA C5 Ultra, C5 Ultra Dual, M4 Aqua, M4 Aqua Dual
