The SmartBand is an innovative life logging wrist band that lets you keep track of everything you do - your movements, your communications, your entertainment. Wearable technology for wherever you go, around the clock. Log special moments and watch your life played back to you on your Android smartphone or tablet.
Your style
The SmartBand is a 24/7 wearable device. It's waterproof and you can keep it on you whatever you do. It's discreet and designed to look great with any clothing style. Choose from a range of vibrant colors and styles and switch them daily to match your mood. An iconic metal Sony fastening button and LEDs give it a premium look and feel. The SmartBand incorporates a removable core unit and a stylish and comfortable wrist band. -
Removable core
The SmartBand incorporates a removable core unit and a stylish and comfortable wrist band. The core contains advanced sensor technology that feels your movements and sends the data to your smartphone. -
Smart alarm
By tracking body movements, the SmartBand will wake you up at the best time based on your sleep cycle. It calculates and measures the best time to wake you up and gently vibrates to bring you out of sleep. -
Life bookmarks
Catch that special moment. Press the Life Bookmark key on your SmartBand and everything going on at that moment is caught and remembered forever. The image of a moment. -
SmartBand, smartphone and Lifelog - empowerment
SmartBand is in constant contact with your smartphone via Bluetooth. A vibrating alert lets you know if a call, message or other notification comes in. When you're enjoying your music on the move you can play, pause and skip tracks using the SmartBand. Connecting is easy using NFC or a standard Bluetooth connecting procedure. Even when you're out of range of your smartphone, this wearable technology saves information about what you do and automatically passes it on when you re-connect. Keep track of your lifestyle and see how you live with Lifelog.
- Sony SmartBand SWR10 activity tracker - 256 KB - black
- Product Type
- Activity tracker
- Tracking Data
- Speed, activity, sleep activity, steps taken
- Connectivity
- NFC, Bluetooth
- Processor
- ARM Cortex-M0
- Storage
- 256 KB
- Notifications
- Missed calls
- Music remote handling, Micro-USB (charging only)
- Supported Host Device OS
- Android
- Battery
- Lithium polymer
- Battery Run Time
- Up to 120 hours
- Black
- 15.3 mm x 7.8 mm x 40.7 mm
- 6 g
- Designed For
- XPERIA C3, E3, M2 Aqua, T3, Z2
- Product Type
- Activity tracker
- Android 4.4 (KitKat) or later
- Notifications
- Missed calls
- Tracking Data
- Black
Storage
- Capacity
- 256 KB
- Wireless Interface
- NFC, Bluetooth 4.0
CPU
- Manufacturer
- ARM
- Cortex-M0
RAM
- Size
- 16 KB
- Technology
- Lithium polymer
- Run Time (Up To)
- 120 hours
- Standby Time
- 120h
- Recharge Time
- 1 hour
- Details
- Wrist strap: 250 mm x 15 g , Wrist strap: 214 mm x 14 g
- Preloaded Software
- Smart Alarm
- Vibrating Alert
- Protection
- Dustproof, waterproof
- IP58
- Included Accessories
- USB charging cable, clip, 2 wrist straps
- -20 °C
- 60 °C
- 5 - 99%
- Designed For
- Sony XPERIA C3, E3, M2 Aqua, T3, Z2
